Gallery, Projects and General > Gallery
small mod on a Chester Comet lathe.
<< < (2/2)
picclock:
Hi Roy
That's a very nice looking job. I did this to my Real Bull 7x14 some time ago and the improvement was spectacular. But I made mine out of a block which could be fitted 4 ways allowing different toolholder offsets and overhangs for awkward jobs. Mine attaches with 4 cap head bolts.
IMHO, its probably one of the most worthwhile mods for smaller lathes, as it allows easy parting and much better finishes just because of the improvement in rigidity. For fine feed a handle on the right hand end of the leadscrew does the trick on mine.
Now if only I could figure out how to turn tapers without having to reset that precision tailstock alignment .. . :scratch:
Best Regards
picclock
jim:
worth while mod :clap:
wheeltapper:
--- Quote from: j45on on May 10, 2011, 05:45:52 PM ---Nice one Roy  :bow:
I have a C4 as well and the top slide is a bit poo I have the gibs locked up almost solid.
I like your solid mounting Idea I may have to copy it  :thumbup:
PS what is that in you tail stock  :scratch:
--- End quote ---
Its a cork, It keeps the crap out. :lol:
Roy
jim:
--- Quote from: wheeltapper on May 11, 2011, 05:50:55 AM ---
--- End quote ---
Roy
--- End quote ---
likewise! its easier to push a cork in, than clear all the crap out!
wheeltapper:
Just as a tailpiece to this I tried a little test.
I set up a dti on the cross slide with the probe resting 2mm from the tip of a r h tool.
taking a 2 mm cut with the toolpost mod I got a tool deflection of .0004"
with the topslide refitted I got over 7 times that deflection.
I think it was worth doing.
there is, however, a downside (isn't there always) I now have no fine feed along the lathe, I have not got a handwheel on the leadscrew and even if I had one it would be a pain because there is no quick way to disconnect the leadscrew apart from removing a change wheel.
Ho hum, you win some, you lose some.
Roy
Navigation
[0] Message Index
[*] Previous page
Go to full version
