The Shop > Our Shop
Shop Move - Part 2
<< < (4/4)
HS93:
this could be a start
http://www.deboerhulls.com/Seaview.htm
Peter
andyf:
If you had cleaned all that swarf off the lathe, it might have been easier to shift.
AdeV:
--- Quote from: andyf on May 03, 2011, 04:39:16 PM ---If you had cleaned all that swarf off the lathe, it might have been easier to shift.
--- End quote ---
That swarf is the only proof I have that I've actually done any work! Besides, I was hoping it would help counterbalance the lathe... it must have worked, because it all arrived in its new home!  :ddb:
--- Quote from: HS93 on May 03, 2011, 04:00:36 PM ---
--- End quote ---
Either that bloke is tiny, or that model is HUGE!!  :lol:
Very tempted to do a Type VIIC U-boat...
lordedmond:
Ade
did you get that dry sump finished its seemed to dry up  :doh:
new Ws looks good its good to start in a new place makes you stand back and consider the positions of the equipment ,when the are connected and in use its a pain to move them around .
Good luck in the new shop nice view outside if you get bored  :D
Stuart
AdeV:
Thanks Stuart - you're right about the fresh view, although I've basically ended up with a very similar layout to what I had before, the main difference being I have some storage/bench space between the lathe & mill now. We shall see how well (or not...) that pans out.
The sump is on-going... but I've made no progress on it recently for a variety of reasons - mostly laziness related if I'm honest, but I will be getting back to it soon & there will be more updates to come...  :dremel:
Navigation
[0] Message Index
[*] Previous page
Go to full version
