Author Topic: HF 7x lathe chuck/rotary table adapter  (Read 10254 times)
Offline dgjessing
« on: April 26, 2011, 06:55:51 PM »
3k words worth:
Seems good & solid, though I've yet to make anything on it yet...
Re: HF 7x lathe chuck/rotary table adapter
« Reply #1 on: April 26, 2011, 07:06:00 PM »
Interesting setup. I have the same RT... been trying to come up with a solution. I assume you drilled out and tapped the center of the RT?
Offline dgjessing
« Reply #2 on: April 26, 2011, 09:57:00 PM »
Mine came with that 6mm tapped hole already in it.
Offline saw
  • lucky amateur
    • Svenssons AckordsWerkstad
« Reply #3 on: April 27, 2011, 04:02:53 AM »
I have one with m8 whole..  :headbang:
_________________________
Greetings / Benni
Offline Troutsqueezer
« Reply #4 on: April 27, 2011, 11:11:50 AM »
I made an adaptor similar to that so I could use my four jaw chuck but I also bought one of these small 3 jaw chucks from H.F. and it's about all I use these days. It fits directly into the MT1 tapered hole in the RT. It's easy to align to the mill, that's for sure.
Not much help for an RT with a threaded hole, I know....
-Dennis-
Once you see the bandwagon, it's too late.
« Reply #5 on: April 27, 2011, 01:11:34 PM »
Mine isn't threaded... just some tapered hole.
Offline saw
  • lucky amateur
« Reply #6 on: April 27, 2011, 01:29:05 PM »
I'll orderd this yesterday http://www.littlemachineshop.com/1888,1187  :headbang:
Greetings / Benni
Offline dwentz
« Reply #7 on: May 23, 2011, 07:14:22 AM »
I have a 7x10 and a Taig that I have lots of 3/4-16 accessories for. Here is what I made for my rotary table
My HF Rotary Tables was threaded and had a taper
The Drill Bit was ground to use as a wide screwdriver to insert and remove the adapter.
Adapter In place on Rotary Table
Table With Chuck Mounted
I also made an adapter so I could mount the chuck to my mill table.
Works great for holding round pieces vertically in the mill.
More details on my web page at http://www.wentztech.com/metalworking/Projects/files/rotab.html
Dale
