Author Topic: Hit n Miss Engine ,,,,to MR D Kerzel's design  (Read 128166 times)
Re: Hit n Miss Engine ,,,,to MR D Kerzel's design
« Reply #125 on: June 15, 2011, 07:03:37 AM »
Rob, thanks for some pictures of your CNC setup...I`m dying to have something to play with in terms of CNC soon!
I spent plenty of time reading over your info and pictures but I must admit, I`ve spent a good 20 minutes trying to work out what book you have been reading, the one the engine is sitting on ... "Surgeons Gen....?   By Pregnant women, premature birth and .... ?"
I was thinking you were perhaps a midwife or something... then I realised it wasn`t a book but a packet of cigarattes!  :doh:
« Reply #126 on: June 15, 2011, 07:12:23 AM »
I forgot to add...what lathe do you use for all your tiny parts - valves and spring retainers etc.
« Reply #127 on: June 15, 2011, 06:19:00 PM »
Chris, I did the same but only for about 5 mins!  :doh:
I'm interested to know the answer to your question too, because the way I see it, you can turn small parts on a big lathe ...
« Reply #128 on: June 18, 2011, 04:45:18 AM »
Cheers Lads  :beer:
Chris / Nick ,,,,,,,,,,,, i used my Myford for the small parts ,,,,,, i do have some were a Lorch watchmakers  lathe that would be idea of small parts ,but its in need of some repair  ::) ,,,,,,,, future project  :dremel:
:lol: :lol: :lol: :lol:  Surgeons General ,,,,,,,,,,, nowt better than smokes  from the USA ,,,,,, i much prefer there health warnings  :)  ............ not allot of shop time this week ,,,,,,, but i did doodle up an idea for a Base/fuel tank ,,,,, stole Pete's idea  :coffee:
So i will  be having ago at that today  :dremel:
Offline Jasonb
« Reply #129 on: June 18, 2011, 06:55:00 AM »
Just hope the carb can suck the fuel up, quite a few of these engines are very choosy about fuel tank level. On teh vertical I'm doing at teh moment it has a fuel pump so its no an issue.
Jason
Offline metalmad
« Reply #130 on: June 18, 2011, 07:29:45 AM »
Hi Rob
That Tank looks great
The mounting tabs are sensational and I doubt u will have too much trouble with the kerzel sucking up the fuel from the tank.
I did  have some trouble filling up the tank due to an air lock, but a breather fixed that.
A little bit every day, sometimes the same little bit!
Offline arnoldb
  • Country: na
  • Windhoek, Namibia
« Reply #131 on: June 18, 2011, 02:32:52 PM »
Great job Rob  :clap:
 :poke: :poke: I see the CNC does the same to you as normal computers  :lol: :lol:; now a DRO would REALLY help you make a mess  :doh: :lol: :lol: :lol:
 :beer:, Arnold
Offline jpm
« Reply #132 on: June 19, 2011, 03:48:49 AM »
Hi   Rob       , question for you, did you find out why you cnc m/c took, as you put it “ a mental” , I was wondering did you programme each pocket separate or program one pocket and loop it to a 60 degree datum shift and repeat it another 5 times , very strange it should go walkabout on the 4th pocket ,???,,,,,,,,,,jeff,,,,,,,,
i didn't know what happiness was like till i got married
now i don't half miss it
« Reply #133 on: June 19, 2011, 04:05:48 AM »
Hi Jeff
I still have no idea why the machine went walk about , as it cut the next two flywheels no problem , I selected all the pocket chains and programmed all to the same depth ,wall offset ,,,,,,, never thought about doing it  "program one pocket and loop it to a 60 degree datum shift and repeat it another 5 times"  maybe because i am not that good  :lol: :lol: :lol:
It could be the old computer i am using  ?
Rob  :D
Offline metalmad
« Reply #134 on: June 19, 2011, 04:12:49 AM »
hay Rob
try using a pencil eraser to clean your computer's Ram terminals,
might give it a new lease on life  :zap:
« Reply #135 on: June 19, 2011, 04:16:33 AM »
hay Rob
I will give it ago Pete   :dremel:
Offline jpm
« Reply #136 on: June 19, 2011, 05:25:03 AM »
Hi Jeff
Rob  :D
I don,t think it is your comp rob , I have a similar problem on  our m/c ,
When I want to machine pockets  equally spaced on a given pcd , rectangle pockets no problem , If I want round pockets ,sometimes  I have to datum shift a fraction of a degree ,( .002 / .oo4 of a degree) after the first pocket , if I don’t it will miss some of the pockets out , we've put it down to an Anomaly in the software, :offtopic: apologies for going of topic in your thread  , enjoying the thread so far rob , some 1st class machining ,, be proud to put my name to any of your jobs , looking forward to more of the same from you ,,,,,,cheers  ,,,, jeff
« Reply #137 on: June 19, 2011, 09:27:30 AM »
Hi Jeff
Your probably right ,,,,,,, maybe a glitch in Mach3  :smart:  ,,,,,,,Dont worry about going OFF TOPIC ,,,, my posts normally do  :lol: :lol: :lol: :lol:
« Reply #138 on: June 19, 2011, 09:32:55 AM »
Jason
Hi Jason
If i have a  hight problem ,,,,,, i will fit a lift pump  :dremel: ,,,,,, loads of room on the carb side of the engine for a small pump  :med:
Offline Jasonb
« Reply #139 on: June 19, 2011, 11:38:44 AM »
You will probably need a different carb as the pump will still be pumping while the engine is missing and will flood the carb. I've just posted some pics of the pump and plumbing for my IHC here
Jason
« Reply #140 on: June 19, 2011, 12:39:50 PM »
Hi Jason
Was planning on pumping the fuel up to a bowel reservoir  ::) just below the carb with a drain back to tank  :med:  ,,,,a bit like a Fairbanks Morse model T carb as used back in the day on stationary engines
« Last Edit: June 19, 2011, 01:21:13 PM by Rob.Wilson »
« Reply #141 on: June 19, 2011, 01:05:23 PM »
Then if it wont run properly I suppose you will also have to add irritable bowel syndrome to the list of possible problems.
« Reply #142 on: June 19, 2011, 01:17:39 PM »
:lol: :lol: :lol: :lol: :lol: oooooooooops  :doh:
« Reply #143 on: June 20, 2011, 03:19:41 AM »
 :lol: :lol: :lol:
Nice one David!  :thumbup:
(Yes, I'm still here......)  ::)
« Reply #144 on: June 20, 2011, 11:34:40 AM »
:lol: :lol: :lol:
NOW thats all i need is Dave D and Dave A ,,,,,,,, Teaming up as a comedy duo  :doh: :doh: :doh:
Rob  :D
« Reply #145 on: June 20, 2011, 11:39:47 AM »
:lol: :lol: :lol:
Rob  :D
Just waiting for Dave BC to turn up!   :D :D :D
« Reply #146 on: June 20, 2011, 11:46:05 AM »
He's here ...
Stuffing Haddock and chips into his face at the moment ...
BC
« Reply #147 on: June 20, 2011, 11:52:00 AM »
Moving on  :lol: :lol: :lol:
Milled up the stock for the tank ,, i machined most of the material away on the HZ mill as it was quicker to do it that way .
Mounted to  my ally fixture plate ready for the CNC to do its job.
First profile complete .
Next up a chamfer around the profile
Next up the O ring grove 1.5mm
Then spot drilling the bolt down pads ,,,,,,,, nearly had a disaster on this operation ,, i for got to program the tool to lift to clear the job as it moved to the third hole  ::)
Pocket next  :dremel:
A bit like watching paint dry is this CNC lark  :coffee:
Job done
« Reply #148 on: June 20, 2011, 11:55:23 AM »
Dave A, BC and D ,,,,,,,,,,,,,,,,,,,,,  :doh: :doh: :doh: :lol: :lol: :lol: :lol: :lol:
mmmmmm fish and chips there's an idea for tea  :thumbup:
« Reply #149 on: June 20, 2011, 12:25:07 PM »
I wonder if we could go through the alphabet with Dave's  :D
Great stuff Rob
:clap: :clap: :clap: :clap:
Tell me what are you going to put in that O ring groove,  :scratch:
