Author Topic: Hit n Miss Engine ,,,,to MR D Kerzel's design  (Read 128197 times)
Re: Hit n Miss Engine ,,,,to MR D Kerzel's design
« Reply #100 on: May 30, 2011, 03:12:52 AM »
Very nice work indeed Rob.
Makes me want to get back into the shop for a few hours fiddling.
« Reply #101 on: May 30, 2011, 04:06:25 AM »
Morning Lads ,,,,,,,,,  :D
Thanks for the comments  :thumbup:
Stew ,,,,,,,,,, look at the photos  :poke: :lol:
Jason ,,,,,,,,,,,,  :lol: :lol: :lol: never seen a Hit n Miss with socket cap screws holding the main bearing caps ,,, this is new age stuff  :med:    ,,,,, Transfers i cant make  them  :doh:   no need for Jib weld only take 2 hours for the mill to make new ones   :)
Cheers Rob
Offline Jasonb
« Reply #102 on: May 30, 2011, 05:14:22 AM »
And I thought they were just while you were building it, to be replaced by studs, washers and single chamfer nuts, proper job :thumbup:
Jason (who has just been making some of these for 3/32" pipe so his engine looks right).
J
lordedmond
« Reply #103 on: May 30, 2011, 07:23:09 AM »
J
Should be no problem I have made them for 1/16 od pipe along with nipples and union nuts  its 3/32 AF if your so minded
These were for the oil lines and steam lines for the drain cocks ( steam operated )
« Reply #104 on: May 30, 2011, 03:52:41 PM »
J
Not on this engine build Jason  :lol: :lol: :lol:  ,,,,,,,,10ba screws make me go boss eyed  ::)
Well i did get into the shop today for a few hours ,, decided to make the cylinder liner .
And then made a start on the cylinder head  :dremel:
Still needs a few more holes to be poked in it ,save those for tomorrow night , and i need to decide what size i will be making the spark plug  :zap:
Cheers Rob
« Reply #105 on: May 30, 2011, 07:10:31 PM »
Is that it Rob?  I was expecting something special!  :jaw:  :)
Bloody hell! Makes what I've been working on look like a kids toy!  ::)
One day I might advance enough? need to make myself a foundry first though  :ddb:
Seriously, very nice work  :clap: you wrote 12,000+ lines of code!!? you must be mental!  :loco:   Looks damn nice though. (fancy doing a few "RS" ones?  :lol: )
« Reply #106 on: May 31, 2011, 12:35:33 PM »
Cheers Ralph ,,,,,,,,,,,,,,,,, :lol: :lol: :lol: :lol: :lol: nope i did not write the lines of code ,,,,, CAM program did that,  :dremel:
PS ,,,,move your butt and get that foundry setup  :poke: :poke: :poke: :D
« Reply #107 on: May 31, 2011, 02:57:07 PM »
Fair enough, it did seem a little excessive!  :lol:
I'd best get a few other things finished first.... Like my long awaited house!    ::)
Offline CallMeAl
« Reply #108 on: June 01, 2011, 12:13:29 AM »
Rob, this little engine just gets more and impressive!
I skin cats my own way!
« Reply #109 on: June 01, 2011, 04:58:28 PM »
Cheers AL   :beer:
A bit more work on the engine tonight  :dremel: , repositioned the R/T to HZ  and drilled the inlet and exhaust ports .
Chopped the head off from the stock and skimmed up the face .
Just needs the valve seats cutting ,, i will probably make up a seat cutter for the job .
Cheers Rob
Offline metalmad
« Reply #110 on: June 01, 2011, 06:16:58 PM »
looking great Rob
 :thumbup:
A little bit every day, sometimes the same little bit!
  • Country: za
« Reply #111 on: June 01, 2011, 06:17:13 PM »
Rob,
Wondering if you ever sleep. :scratch:
Really very nice and excellent machining :clap: :clap: :clap:
Go to bed and give me a rest :D :D :D
« Reply #112 on: June 01, 2011, 06:52:04 PM »
Fantastic Rob  :clap: :clap: :clap:
« Reply #113 on: June 02, 2011, 03:43:15 AM »
Developing beautifully, Rob!  :clap: :clap: :thumbup:
« Reply #114 on: June 02, 2011, 01:37:49 PM »
Wow Rob, that is great.
Only 300 more years of practise and I might come close to that! Just watch out :lol:
Offline klank
  • Sunny East Devon
« Reply #115 on: June 03, 2011, 10:48:24 AM »
Really excellent, Rob - something for us mere mortals to aspire to.
Peter
« Reply #116 on: June 05, 2011, 12:16:17 PM »
Thanks Lads and cheers for looking in  :headbang:
A wee bit progress today , turned up a couple of brass valve guides  :dremel:
Next was a couple of stainless valves ,, i decided to turn them from 1/4 bar instead of the described method in the drawings .
Then a couple of valve spring keepers also in stainless
Time for tea  :med:
  • Country: za
« Reply #117 on: June 05, 2011, 02:53:48 PM »
Rob,
Some nice turning there. :thumbup:
Especially the stainless. :clap: :clap: :clap:
Offline arnoldb
  • Country: na
  • Windhoek, Namibia
« Reply #118 on: June 05, 2011, 03:02:00 PM »
 :bow: :bow: Well done Rob  :bow: :bow:
Great photos as well mate  :thumbup: ; you'd better blur them a bit else someone's going to steal your fingerprints   :lol:
 :beer:, Arnold
« Reply #119 on: June 05, 2011, 04:43:54 PM »
Nice  :bow: :bow: :bow: :bow:
Mind i thought you would have used triplex cotters to retain the valves. :lol: :lol: :lol: :lol:
I cant remember seeing a microscope in your shop but you must have one  :scratch: :scratch: :scratch:
I have trouble with full size stuff at work.
With out doubt a true insperation
Offline metalmad
« Reply #120 on: June 06, 2011, 03:54:32 AM »
looking forward to to seeing it run
 :ddb: :ddb: :ddb: :ddb: :ddb:
« Reply #121 on: June 14, 2011, 04:14:24 PM »
Cheers Lads  :beer: :beer:
Just a bit of an up date ,, Things have been a bit slow had a few other workshop jobs to take care of  :dremel:
Any way ,, the flywheels up next .machined up the flywheel blanks and decided to CNC the cut-outs for the spokes  :dremel:
Here is my small CNC set up Denford Starmill and Mach3
Mounted a 4 jaw chuck to hold the blanks ,,,,,,,,,, going to make a proper fixture for flywheels  :proj:
I used the find centre wizard in Mach3 to locate the blank centre
Then off we go  :ddb: :ddb: :ddb: :ddb:
NOT FOR LONG ,,,,,,,,,MACHINE TOOK A MENTAL  :lol: :lol: :lol: :lol:
No idea why it just did  ::)
Machined up the second one ok ,,,,,,,, wile it was chugging away machining the second blank  i turned up another  .
« Reply #122 on: June 14, 2011, 05:56:09 PM »
As usuall Rob stunning work
Offline metalmad
« Reply #123 on: June 14, 2011, 06:28:10 PM »
nice touch with the keyways Rob
Im sorry now I did not do the same on mine  :coffee:
Looking great
« Reply #124 on: June 15, 2011, 05:52:48 AM »
Nice Rob  :clap: :clap:
