Author Topic: New Furnace Build ,,, Cupola  (Read 113674 times)
Offline RotarySMP
  • Country: at
Re: New Furnace Build ,,, Cupola
« Reply #50 on: September 28, 2012, 05:01:39 PM »
Call me a stalker, but madmodder.net has a search function - all post by user. I looked at all the pictures you have ever posted to MadModder Rob, and am truely impressed at the quality of your work.
Thanks for sharing your skill and knowledge.
Mark
« Reply #51 on: September 29, 2012, 03:52:04 AM »
BLUSH Thanks RotarySMP
Do you do any casting ?
Offline RotarySMP
  • Country: at
« Reply #52 on: September 29, 2012, 06:54:51 AM »
A little. Started about a year ago. I have a little A5 furnace built to Anon (www.alloyavenue.com mpderator) design.
My casting so far are here: http://s1124.photobucket.com/albums/l579/rotarysmp/
Just a raw beginner.
« Last Edit: September 30, 2012, 03:57:48 AM by RotarySMP »
Mark
« Reply #53 on: September 29, 2012, 04:35:24 PM »
Looks like your off to a good start , motor mount looks good and solid  :thumbup:
Offline RotarySMP
  • Country: at
« Reply #54 on: September 30, 2012, 03:56:01 AM »
Hi Rob,
Not sure it is a good idea posting photos of my work in your threads. The casual oberver might think its from you, and that you have lost your touch.   Your reputation is at stake :)
People already suspect you have issues milling out square...
I don't mean to highjack your cupola thread, but when I machined my two motor castings, I drilled through the hinge axis with a long (~200mm long 6mm drill). Even with center drilling, I ended up with the axis alittle squewed off. You can see in the tensioning widget, that things didn't line up very well.
How would you have gone about that?
Mark
« Reply #55 on: September 30, 2012, 04:55:40 AM »
No worries , the cupola build has stalled for now due to other jobs  :proj:
I would have marked each lug out and drilled them individually ,from either side .
Offline RotarySMP
  • Country: at
« Reply #56 on: September 30, 2012, 06:03:48 AM »
Thanks. I was trying to avoid that, guess it would have been the better of two unattractive options.
Mark
Offline ironman
« Reply #57 on: October 01, 2012, 12:51:48 AM »
Good to see that someone is going to build a cupola. I have had years of experence in running one (9" dia). they can be very temperamental furnace to run so If you need help I can help.
« Reply #58 on: October 01, 2012, 12:00:53 PM »
I probably will not get this project finished until next  year ,so many other shop jobs  :palm: , when i get stuck and i probably will , I will give you a shout .
Offline Mayhem
  • purveyor of mischief
« Reply #59 on: May 01, 2013, 08:12:08 AM »
Bugger - I only joined up to see this build  :lol:
« Reply #60 on: May 01, 2013, 01:00:52 PM »
 :lol: :lol:  I was actually looking at the furnace last night  ,,,,,,thinking I may do a bit work on it now that the weather has improved a bit , have a break from the 626 project .
Just looked its been two years since I started the build ,,,,,,,,,fook me I am slow  :lol: :lol: :lol:
« Reply #61 on: May 01, 2013, 01:54:24 PM »
Never mind Rob, my 100kW Induction Furnace and my Propane Furnace are still not unpacked from moving here 5 1/2 years ago I'm ashamed to say !
« Reply #62 on: May 23, 2013, 09:25:05 PM »
It  has been raining here for 3 days but there was enough of a pause late today for me to cut up some 1/2" rebar and make up 2 botting irons and 2 tapping bars.
Better hurry Rob or I'll be the first to watch slag dripping out of my cupola into a pouring ladle!
Puttin on the pressure, uhhuh, uhuh :headbang:
Offline tekfab
« Reply #63 on: May 24, 2013, 04:31:58 AM »
Thats not what your wife told me  :D   :D
« Reply #64 on: May 24, 2013, 12:39:32 PM »
 :lol:  Steve you win  :lol:
I still have bott sticks , pokey stick  :poke: , blower , crucible poring shank and the furnace to finish  :Doh:
Better go and look for a motor for the blower ,,,,,,,or I will be hand cranking   :(
« Reply #65 on: May 24, 2013, 07:16:53 PM »
Ah, well Rob, I've got the drop door to do, the lid to line, lid lift and swivel mechanism, pouring shank, ladle, pig molds to weld, as well as make up some iron sand. So false bravado, here!  :lol:
Offline Mayhem
« Reply #66 on: May 24, 2013, 08:34:34 PM »
c'mon you two - less talking and more action (with pics - lots of pics)!
« Reply #67 on: May 27, 2013, 11:04:22 AM »
Here we go  :)
After spending most of the weekend sorting out my workshops , had to take advantage of the good weather , I managed to drag  the furnace into the fab shop , it was a bit of a fight , big spiders and the ivy had grown over it  :palm:
First job was to remove the centre form .
before.
After ,
then a bit work to the stand ,I noticed this had a fare bit of spring in the legs when I was dragging it into the shop and the corners of the box section were also digging into the flags .
So some tubing was added to brace the legs , nice a stiff now . Some 4 inch bar was sliced up to make feet .I rounded the edge so they would slide easier.
these were then welded to the bottom of the legs .
still a bit work to do to the stand .
I better move my arse as Steve has had fire in his furnace  :D
« Reply #68 on: May 27, 2013, 01:57:10 PM »
Woohoo!
That is one impressive cupola.  :bow: :bow: :thumbup:
Mine did come along a little faster.
Just like a fire in a dustbin is faster to prepare for than constructing a convection oven for a pastry chef.
Any time you want to trade, Rob, just let me know!
« Reply #69 on: May 27, 2013, 02:14:26 PM »
Looking good Rob
The legs wont be flexing now  :lol: :lol: :lol: :lol: :lol: :lol:
« Reply #70 on: May 27, 2013, 03:28:08 PM »
can rost sum nuts with that rob well dun
« Reply #71 on: May 27, 2013, 05:50:04 PM »
LOL, LOL!
Lets hope not....
« Reply #72 on: May 28, 2013, 03:58:29 PM »
Thanks Lads  :beer:
Only had an hour in the shop tonight so I decided to make the shoot ,were hopefully molten iron will flow from .
So I grabbed an off cut of 100mm box .
Set it at an angle I was happy with and marked both sides with chalk .
A couple of minutes with an angle grinder .
so I now had a shoot shape .
I decided to bend out the sides using a 2ft adjustable.
Once I was happy with the angle , mark one eye ball .
I needed to bend the other side the same , the original measurement between the walls was 90mm
I had bent the first side out 20 mm
so all i had too do was bend the other out until the gap was 130mm
then both would be bent equal , well close enough for this job.
the bit scrap that was cut from the box previous was re welded in at the front for the shoot to form a lip.
The shoot was then welded to the drop bottom .
would have took me 40 minutes if I did not stop to take photos  :lol: :lol: :lol:
Cheers Rob
« Reply #73 on: May 28, 2013, 04:26:56 PM »
Superb piece of work, Get yersen a broon!
Offline tekfab
« Reply #74 on: May 28, 2013, 06:13:14 PM »
Is this an Australian Cupola ?   :D
