Gallery, Projects and General > How do I??
How do I fix my milling machine runout?
<< < (2/2)
andyf:
Hi Chris,
Looks like the ER32 collet holder, or the collet itself, is a bit out of whack, though obviously better than the drill chuck. Try the DTI on the taper within the collet holder. Also, make sure that the spindle taper, the taper in the collet holder and the collet itself are all scrupulously clean. Though more likely to happen when ERs are used on a lathe, tiny chips can enter the slits in ER collets, and be left behind when the collet is removed, or lurk in the slits ready to cause trouble when the collet is re-inserted.
Anzaniste:
I have the same problem on an ER32 collet chuck on my lathe ( http://madmodder.net/index.php?topic=4439.0 ).
I plan to grind the inside of the collet chuck as suggested but this means making an internal grinding spindle for my tool post grinder which has delayed proceedings.
I  also have an ER 32 Collet chuck on a No2 Morse taper for my Centec mill. So far I have not checked the run out bot I expect there will be more than I Want. I will check it and grind out at the same time as my lathe chuck. I ill be disappointed if there is more than .001" TIR run out. After-all that is why one has a collet chuck.
jiihoo:
Well well, 0.17 runout on the drill chuck and 0.09 on the ER collet. If your collect is about half the length of the drill chuck (measured from the spindle nose to the end where you did the measurement), then that would really point towards the spindle or Morse taper, I am sorry to say.
One more experiment that you could do: Put the drill chuck (or collet) back on and measure the runout. Find the spot where you have the most positive runout value and mark it on both the spindle and the drill chuck. Remove the drill chuck from the spindle, turn it 180 degrees (half a turn) and put it back on. Your marks are now on the opposite sides. Measure again. If the culprit is the drill chuck, then the most positive runout value will be found near the mark on the drill chuck. If the culprit is the spindle or Morse taper on the spindle, then the most positive runout value will be found near the mark on the spindle (opposite the mark on the drill chuck).
Cheers,
Jari
Stilldrillin:
Have you checked your bearings for play, Chris?
Clock on spindle, no gear engaged. Pull/ push gently to measure any slop.....
Bogstandard:
As you have already checked the inside of the spindle for runout, which seems, within your measuring capabilities, as OK, then really the things to suspect are the bits you are wacking up into it.
You should find it much easier to check for runout of tooling using your lathe, and I think as yours has a morse taper spindle, it is easy to stick the bits what you want to check into that.
Unless you have made the tooling and arbors yourself, and you know they are right, then don't trust cheap tooling at all, always check and put things right before using.
I have been very lucky with my keyless drill chucks and arbors from RDG, both R8 & MT3, I have about a dozen of them, and none have any detectable runout. As for ER collet chucks, mine is a very early one, and runs perfectly true, but I have had to true up a couple of new ones for people that have had runout as much as 0.004" (0.1mm). That figure must be less than 0.001" (0.02mm) or even better, none at all, otherwise, they are not worth using.
They don't have to be ground, if you are very careful, they can usually be trued up with a normal cutting tool and using the topslide set up exactly to the correct angle.
I've done a post somewhere showing how I cut the taper for an ER collet chuck, the same method could be used for truing.
Navigation
Message Index
Previous page
Go to full version
