Author Topic: Mill Engine  (Read 15262 times)
Mill Engine
« on: March 11, 2011, 05:28:42 PM »
I seem to have gotten bogged down with my v twin marine engine  :( :( :(
 So i have started another project.
Going to build a big mill engine :D :D :D :D
I made a start on a pattern for the cylinder
I want it to have a 4 inch stroke and a bore of at least 2 1/2 inch no bolts smaller than 5 mill  :) :) :) :)
It will be double acting with a slide valve , nice and big and simple  :) :) :)
Once i have my cylinder i will be able plan things out
Glued some magic wood together last nite
Started to square up the ends for the driving dog
Poor boxford is contaminated again  :( :( :( :(
Re: Mill Engine
« Reply #1 on: March 11, 2011, 05:32:02 PM »
What happend with your'e v twin marine engine ?  :smart:
Re: Mill Engine
« Reply #2 on: March 11, 2011, 05:37:27 PM »
It is about 80 % done just seem to have lost interest  :( :( :(
It will come back and i will finish it :D :D :D :D
Just needed a change from fixing machines and making tooling  :doh: :doh: :doh:
Re: Mill Engine
« Reply #3 on: March 11, 2011, 05:41:55 PM »
Ok I missundersud you, I thought som shocking hade happend (dropped on the floor ore something
). I can understand that you need something else to do.  :thumbup:
Re: Mill Engine
« Reply #4 on: March 11, 2011, 07:35:34 PM »
Neat idea of using the spindle for a clamp.  :clap:
Re: Mill Engine
« Reply #5 on: March 12, 2011, 03:49:42 PM »
Got a bit more done on the cylinder pattern
MDF needs to run fast with a heavy cut  :D :D :D
Re: Mill Engine
« Reply #6 on: March 12, 2011, 04:00:54 PM »
Looking good.  :thumbup:
Re: Mill Engine
« Reply #7 on: March 13, 2011, 07:46:15 PM »
More sanding and filling :( :( :(
getting there
Re: Mill Engine
« Reply #8 on: March 20, 2011, 04:01:21 PM »
Today i managed to turn the wood in to bronze
TWICE  :( :( :( :(
Pattern all ready to go
Core mould and cores
Top half of mould showing feeder and riser
Core in place
Top half of mould showing "gate "
Smoking core
Looking good
The finished casting
You can see how the metal has not filled the port face fully
Rob Wilson came over for an inspection
We re cast it with the same result.
Some mods to the pattern and moulding method and the job should be a good one
Re: Mill Engine
« Reply #9 on: March 20, 2011, 04:14:51 PM »
Good luck with redone the job.  :thumbup:
Re: Mill Engine
« Reply #10 on: March 27, 2011, 04:59:28 PM »
Took Rob Wilsons advice and split the patern the other way. :thumbup: :thumbup: :thumbup:
This also gave the opertunity to add the exhaust port flange and cylinder drains.
After much sanding and filling the finished patern
Hopefully this will be cast this week  :) :) :) :) :)
Re: Mill Engine
« Reply #11 on: March 27, 2011, 05:13:16 PM »
 :clap: :clap: :thumbup: Looking great john
Re: Mill Engine
« Reply #12 on: April 03, 2011, 03:58:35 PM »
Today the plan was to turn the nice red patterns into bronze
I have been looking forward to this all week
Yesterday i baked the cores and rammed up the moulds
These were carefully assembled ready to cast today
Extended risers were used to make sure the mould would fill completly
Rob Wilson called in to oversee the pour
Cylinder we cast last time ready to melt
Fired up the furnace soon had a nice crucible of liquid bronze
The pour went ok but i seemed to be short on metal
The pattern is biger than last time
Not looking to bad
Not enough metal
On closer inspection the core had collapsed
Rob examined the miserable looking casting his verdict
The damp casting sand had softend the core ccausing it to break up during the pour
Wont be making up any more moulds the night before
Going to cast it in aluminium tomorrow nite just to make sure the crucible holds enough metal
If it was easy every one would be doing it
Re: Mill Engine
« Reply #13 on: April 03, 2011, 05:21:57 PM »
And most probably walking on water as well. :med:
I find you learn more from making mistakes than doing it right first time, and thanks for showing that we all have problems sometimes.
I'm sure you will have a Cheshire Cat grin soon. :D
