Gallery, Projects and General > How do I??
Vertex 4" Rotary Table
<< < (3/3)
raynerd:
Chuck, this is how I made my adapter for my vertex rotab and it seems to work just great.
http://madmodder.net/index.php?topic=2242.0
Bogstandard:
Here is another one, from the start of where I get to doing the RT.
http://madmodder.net/index.php?topic=4040.msg44911#msg44911
Chuck in E. TN:
From Bogs thread on his RT build up:
--- Quote ---There is no way these two are going to come apart in normal use.
--- End quote ---
One question, John. Why grub screws at the join, and not screws from the sides? I tried to copy the picture below the quote I'm refering to, but could't figure out how to do it.
Chuck in E. TN
Bogstandard:
Chuck,
That is a standard procedure for fixing two parts together. There are threads in both pieces of material, so it it will stop it pulling apart straight up by the fact that the grub screws lock the parts together, plus they cannot rotate against each other either. Whereas screws in from the side are a very weak fixing all round compared to this method, unless the screws actually penetrate thru both pieces and well into the inner piece.
Also by doing it this way, the screws cannot be seen and it looks just like a one piece part.
Chuck in E. TN:
Thanks for the explanation, Bogs. Makes sence to me.
Chuck in E. TN
Navigation
[0] Message Index
[*] Previous page
Go to full version
