Author Topic: Myford slotted quadrant  (Read 19645 times)
« on: January 15, 2011, 10:49:22 AM »
Hi Lads ,, a bit help needed
Has anyone got a myford slotted quadrant for metric /dp/ba threads ,, if so any chance of a photo and a bit measure up of it  :dremel:
Thanks Rob
Re: Myford slotted quadrant
« Reply #1 on: January 15, 2011, 11:30:36 AM »
Hi Rob
Is that the thing with two slots at an angle ?? And a biggish hole at one end to pivot on ????
like this ...
« Last Edit: January 15, 2011, 11:43:07 AM by Bluechip »
« Reply #2 on: January 15, 2011, 11:36:22 AM »
Thats the bugger Dave
You got one  :D
« Reply #3 on: January 15, 2011, 11:44:07 AM »
Hi Rob
Nope, sorry ..
Never seen one before in me life    :lol:  :lol:  :lol:  :lol:  :lol:
BC
« Reply #4 on: January 15, 2011, 11:48:16 AM »
Hi Rob
Nope, sorry ..
BC
TWAT  :lol: :lol: :lol: :lol: :lol:  i was all excited there Dave
Funny just looked up  :doh: photo was not there before  :poke: :poke:
« Last Edit: January 15, 2011, 11:56:41 AM by Rob.Wilson »
« Reply #5 on: January 15, 2011, 11:50:38 AM »
Hi Rob
YES  I've got one... just took the piccy ...
Sorry, a bit dieseled up at the mo.
Been on the sozzle  :beer:
What measurements do you want .. all of them ???
BC
« Reply #6 on: January 15, 2011, 11:53:48 AM »
Hi Dave  :D
Is one side flat ,, the side were the gears it ,,,,,,, if so will it scan  :dremel:
« Reply #7 on: January 15, 2011, 11:55:38 AM »
Hi Rob
Yes-flat-ish ...
Shall we do this on SKYPE ... fingers quite out of control ...
BC
« Reply #8 on: January 15, 2011, 11:57:38 AM »
Ok Dave  :thumbup:
« Reply #9 on: January 15, 2011, 12:02:25 PM »
Eeeeeeee, owd on lad .... piccy to follow...
BC
« Reply #10 on: January 15, 2011, 12:07:01 PM »
What a Star  :bow: :bow: :bow: :bow:  :D
Just what i need  :D i no the bore size so i can work everything out from that  :ddb: :ddb: :ddb:
Cheers Rob
« Reply #11 on: January 15, 2011, 12:09:26 PM »
Cheers Rob
Hi Rob
Don't forget the other side has a boss on it .... not flat ..
BC
« Reply #12 on: January 15, 2011, 12:15:20 PM »
Cheers Rob
Hi Rob
BC
:thumbup:  i will work from the non slotted one , the one i have for those dimensions  :dremel:  :ddb: :ddb:
« Reply #13 on: January 15, 2011, 02:16:39 PM »
Why do you need one ?
John S.
« Reply #14 on: January 15, 2011, 02:24:41 PM »
Hi John
So i can cut a 16 DP worm on a shaft   :dremel:
« Reply #15 on: January 15, 2011, 02:31:13 PM »
Hi John
Don't let the RSPCA find out ...  :lol:  :lol:  :lol:
BC
« Reply #16 on: January 15, 2011, 04:33:46 PM »
Is this on a Myford with gearbox ?
« Reply #17 on: January 15, 2011, 04:52:33 PM »
Spot on John ,,,,,,,,,, it is  :thumbup:
What you thinking ?
« Reply #18 on: January 16, 2011, 04:15:36 PM »
Pattern nearly done ,,,,just needs a final rub down and top coat  :D
« Reply #19 on: January 16, 2011, 04:47:12 PM »
Don't know if it will physically fit but if you replace the 24tooth gear with a 52 tooth one and select 11 tpi that will give you the same ratio, or very, very close to it.
John S.
« Reply #20 on: January 17, 2011, 03:09:10 PM »
Hi John
probably would  :thumbup: i worked it out to be  very close to 5TPI  ,,,,,,,,,,, done casting now  :coffee:
« Reply #21 on: January 17, 2011, 06:30:00 PM »
 :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow:
Your castings .....  I wish I had that facility!!!! One day... I need to build the flowerpot furnace!!
Offline Gerhard Olivier
« Reply #22 on: January 18, 2011, 03:26:19 AM »
What Chris said  :bow: :bow: :bow:
Gerhard
Guernsey
Channel Islands
« Reply #23 on: January 19, 2011, 04:23:47 PM »
Cheers Lard  :thumbup:
Chris ,,,,,,,, its well worth the effort to set up a small foundry  :dremel: :ddb: :ddb: :ddb:
Here it is machined up ,,, pattern needs to be altered as i had a slight miss calculation on the thickness  :doh:  ,,,This one will get me by until i cast another in cast iron this summer .
Now i can get back to  what i was doing  :ddb: :ddb:
« Reply #24 on: January 19, 2011, 04:31:22 PM »
Lovely jubly that man
:thumbup: :thumbup: :thumbup: :thumbup:
