Author Topic: Powere sources for a stirling  (Read 27061 times)
Offline Bogstandard
  • Bogs Group
« on: December 23, 2010, 12:51:04 PM »
Nick,
It is frustrating, but just another trial on the journey thru life. A shrug of the shoulders and carry on doing what you enjoy.
This is way off topic, but this post is going nowhere until my metal stuff turns up. So I may as well show something of interest.
I don't know if you have seen it before Nick, but this is the one I dropped.
http://www.youtube.com/watch?v=6VsuC9sLT9U
When eventually the storage box gets opened again, I will finish off all three that are all made except for assembly, and of course, make a new crank for this one.
I am wondering if they will run off the heat of the heater pads they put under vivariums, rather than an eggcupful of water being heated by a candle. They would be a lot safer for me, if they work.
I can't be trusted with matches any more.
Location - Crewe, Cheshire
Skype - bandit175
« Reply #1 on: December 23, 2010, 01:19:13 PM »
What about putting  cheap 50/100w  soldering iron element into a block of aluminium? You could control the heat/temperature with a simple  light dimmer
e.g.
http://cpc.farnell.com/duratool/d00757/heater-element-for-zd-415/dp/SD01389
Offline Bogstandard
  • Bogs Group
« Reply #2 on: December 23, 2010, 01:43:18 PM »
A good idea Bill, unfortunately I think I will need a few to cover the area I want. I would like a small table top, say 18" square, where maybe a dozen low temp stirlings could sit, all running.
Vivarium heaters are ready made heating pads, and you can get them in fairly large areas for not too much money. I think they only generate heat on the area that is covered.
http://www.discountleisureproducts.co.uk/Heat_Mats
I just don't know if they will provide enough heat. I will have to buy a small one and try it.
I think I still have some 1/4" diam heating elements from when I was working on cellulose ribbon cutting. The only problem is, they glow red hot when working, and the electric meter would spin itself off the wall.
Skype - bandit175
Offline slowcoach
« Reply #3 on: December 23, 2010, 01:51:00 PM »
Hi Bogs, What about using a few peltier pumps. http://www.greenweld.co.uk/acatalog/Shop_Peltier_76.html
Rob  :thumbup:
Offline Bogstandard
  • Bogs Group
« Reply #4 on: December 23, 2010, 02:01:54 PM »
Rob,
Getting rather expensive for the size I want to do. A quickie calc comes out around 3,200 squid, plus maybe a bit of overkill.
I am looking for a KISS solution.
I was hoping someone would have a vivarium AND a low temp Sterling and maybe they could try it out for me.
« Last Edit: December 23, 2010, 02:05:58 PM by bogstandard »
Skype - bandit175
Offline slowcoach
« Reply #5 on: December 23, 2010, 02:07:41 PM »
Yeah, it is a little steep that  :bugeye:
Offline Bogstandard
  • Bogs Group
« Reply #6 on: December 23, 2010, 02:16:31 PM »
Everyone, please don't stop coming up with suggestions just because I have shot a few down in flames.
Your ideas might spark of something in someone else's projects.
Those peltier jobbies, I think, would be ideal for running just one, sitting on a nice ali or marble base. I know the experts at Harrogate use small tungsten bulbs for theirs.
Skype - bandit175
« Reply #7 on: December 23, 2010, 02:19:25 PM »
Maybe a hairdrier, heating an ally plate from below?
Offline mklotz
  • LA, CA, USA
« Reply #8 on: December 23, 2010, 02:23:16 PM »
Although it deeply offends my model engineering sensibilities to run Stirling engines on electricity, the Peltier device does offer an interesting possibility.  Clamp two identical Stirlings to each side of the Peltier plate and run them both simultaneously.  Sit back and have a good laugh as technically clueless onlookers try to explain what's happening.
Regards, Marv
Home Shop Freeware
Offline Jasonb
« Reply #9 on: December 23, 2010, 02:26:04 PM »
What about a hot plate or plate warmer, these usually have an element set into a glass/ceramic and have a thermostat, would also keep your coco warm :thumbup:
Jason
« Reply #10 on: December 23, 2010, 06:07:38 PM »
Have never been into (making) homebrew but they sometimes use low-level heating mats like these to aid fermentation.
Offline Bogstandard
  • Bogs Group
« Reply #11 on: December 24, 2010, 12:55:23 AM »
Jason,
Now that looks a good idea, just need to find a reasonably priced one than heats continuously.
Marv,
I know exactly how you feel. Unfortunately, nowhere in the UK any more allows you to display with naked flame, or are very reluctant to let you do so, so I am actually making some tiny bunsens for the ones that normally have a meths or candle, hoping that will satisfy them. I used to display a fair amount at one time, but there are just a couple of local ones I would like to try to attend in the future.
About the Peltier devices, good idea, will Stirlings work with cold on the bottom plate, and do low temp stirlings run when on their side or upside down, or would the friction be too much?
Dave,
I think they are the same as the vivarium heaters, just more expensive.
Skype - bandit175
Offline mklotz
  • LA, CA, USA
« Reply #12 on: December 24, 2010, 12:30:44 PM »
Stirlings require only a temperature differential to run.  They don't care which end is hot and which cold.
At shows, I run my LTDs by sitting them on one of those freezer packs one can buy for use in picnic coolers.  With the sun warming the top plate and the freezer pack cooling the lower plate they run quite nicely, albeit in the opposite direction of rotation from the heated lower plate configuration.
My LTDs will run upside down but that may be a fluke.  I suppose one could "pipe" the bottom side of the Peltier device to the (right side up) engine somehow.  A thin aluminum or copper plate could act as a pipe.
Regards, Marv
Home Shop Freeware
Offline NickG
« Reply #13 on: December 24, 2010, 02:37:20 PM »
John, that's brilliant, really good. As Marv said, it would just run the other way if you cooled the bottom. Mine doesn't run (not that surprised, didn't have time to troubleshoot and there were a number of things I knew were iffy) but I've had to package it up for my dad's present tomorrow - pretty rubbish present though, just hope he can see that I've put quite a bit of effort into it  :( . I guess I'll try to make another one for myself, maybe but got a stack of other projects to do too.
Nick
Offline Bogstandard
  • Bogs Group
« Reply #14 on: December 24, 2010, 03:17:09 PM »
Thanks very much for the info Marv, it gives me something else to think about now.
Nick,
I still haven't forgotten. When I get them finished, one of the burners, and a gas regulator, will be on it's way to you, for either your flame gulper or a hot cap Sterling, if you build one.
Thank you everyone for your ideas on the heating solution.
« Last Edit: December 30, 2010, 01:16:48 PM by bogstandard »
Skype - bandit175
Offline madjackghengis
  • big engine
« Reply #15 on: December 25, 2010, 09:20:33 AM »
Hi John, didn't want to push you on the issue, but I've dropped my share of carefully machined bits and pieces, and don't much care for having to redo what I've just finished.  I've just gone through the whole of your log, and got a better understanding of the many issues which have come out in it.  I try to salvage everything which once worked doing anything, and have several old coffee makers, disassembled, and their "hot plate" for keeping the pot warm would probably work fairly well, they have a thermostat in them, to keep it below boiling, if you put a diode that will carry ten amps, such as a 4004, you cut the heat in half, and would probably make it better for the LTD types, and even for the not so LTD, but close types.  The same mod with the diode can be used in any electrical circuit of a/c, and cut your wattage in half, I've used it with an old coffee pot to keep wax melted, but not burning, for dipping sharpened tools to protect the edges, before.  I've also got several "potential boilers" which have come from expresso machines, as I truly enjoy my expresso in the winter, when I can drink it, and while they don't meet esthetic standards as boilers, they probably would meet safety standards of the "safety police" who seem to poke noses into everything these days.  By the way, what are you using for your displacer, if you don't mind my asking? :bugeye: mad jack
Offline Bogstandard
  • Bogs Group
« Reply #16 on: December 25, 2010, 12:25:31 PM »
They are a little small in surface area Jack, I want to make a heated table to accommodate about eight to ten smallish Ltd engines. You can in fact buy small coffee mug warmers that plug into an USB port that could be used if you wanted a Ltd Sterling on your desktop.
For my eggcup Stirlings, I used thin slivers of building foam (about 3mm or 1/8" thick) for the displacement pistons, but now I have some thin acrylic (2mm), which I will use when they are rebuilt. I have noticed that the foam is 'sagging' slightly and is going slightly mis-shapened after being in there a couple of years. Even very light materials succumb to gravity after a while, especially when supported at just one point.
« Last Edit: December 25, 2010, 12:27:46 PM by bogstandard »
Skype - bandit175
  • big engine
« Reply #17 on: December 26, 2010, 09:43:42 PM »
Hi John, while I've not yet built an LTD stirling, from the way most are made, it would seem pretty natural for them to run upside down just as well, since all the movement is verical except the rotation of the flywheel.  That double engine Peltier device idea ought to work out pretty well as long as everything is pretty well balanced.   :bugeye: mad jack
Offline Bogstandard
  • Bogs Group
« Reply #18 on: December 29, 2010, 05:45:19 PM »
Jack, I just might try that out on the eggcup ones I have yet to assemble.
« Last Edit: December 30, 2010, 01:18:11 PM by bogstandard »
Skype - bandit175
« Reply #19 on: December 29, 2010, 06:57:28 PM »
Anyway, the bearings turned up today for me to carry on with this Division Master topic.
So the postings about heat sources and Sterling engines is now closed. Many thanks to all those who contributed, it has given me a lot to think about.
Thank Christ for that.........................
Offline j45on
Re: Powere sources for a stirling
« Reply #20 on: February 10, 2011, 07:38:30 AM »
Sorry to resurrect an old thread but I thought these may be of use to somebody.
They are tiny ceramic heaters carefully cut out of car O2 sensors
(potentially free from scrappies as they are pocket size )
They run on 12v and the one on the left reaches 230 c quite quickly
The one on the right I have not tested for temperature yet
Maybe they could be fitted to in to a base plate with a thermostatic switch ?
Jason
Offline cuog
« Reply #21 on: February 10, 2011, 09:48:05 AM »
I guess since we're pulling this thread back from the dead, any reason an electric griddle wouldn't work?
One of these: http://www.amazon.com/Presto-07030-20-Inch-Electric-Griddle/dp/B001078UCC/ref=sr_1_4?ie=UTF8&qid=1297349186&sr=8-4
I can't see why such a device wouldn't be for sale in the UK, but it is a strange world out there so who knows.
Offline cidrontmg
« Reply #22 on: February 10, 2011, 10:14:10 AM »
About the vivarium mats. I don't think they will be warm enough for your purposes, Bogs. They all seem to be 28 cm wide, the length varies with wattage. The smallest, 15x28 cm, puts out 7 watts to that area. It's not much. Many years ago I was working with IC chips that dissipated some 5 watts to a device of 17 mm x 52 mm x 4 mm. The IC was warm to touch (finger), I figure about 40 Co. The surface area (17 x 52 mm) = 8.84 cm2. The surface area of the 7 watt mat is 420 cm2, or 47 times bigger. I can't imagine that power to be able to warm the mat more than a few degrees above ambient, even well isolated from excessive cooling. Which well may be what the reptilians prefer, but hardly enough to power a LTD Stirling.
There are also electric blankets, and similar electric bed warmers to be used above the mattress. We have a number of those, in their intended use, and they are very nice! Their power/heat can be (usually) adjusted in steps, and they might offer an alternative. Except they are maybe too large (=size of a bed). But you could maybe build some more LTD Stirlings...  :)
Olli
Penafiel
Portugal
Offline picclock
« Reply #23 on: February 11, 2011, 03:20:54 AM »
Hi Bogs
The surface are that you are heating is quite large, and I'm guessing that you will need a temperature of 50-60C for the stirlings to work well. So you probably need a reasonable power output to warm it up quickly and temperature control to make sure it doesn't get too hot.
If you can live with the depth, how about an electric iron with the sole plate attached to your aluminium sheet (upside down). The handle can be removed, but the temperature controller is built in and attached to the iron sole plate.
If that's too deep, a scrap slow cooker should contain the heating elements and controller you need although you would have to preserve the wiring and remotely mount the thermostat control, which may be a good thing if you want a external controller.
I think you will need a lot of watts for this to work well, so covering the top with an insulator, using cutouts for the engines will help to maintain an even temperature and increase the temperature differential (If you have an exposed hot plate the cold ends are going to warm up pretty quickly).
Just a few ideas, hope they are useful.
Best Regards
picclock
Offline Bogstandard
  • Bogs Group
« Reply #24 on: February 11, 2011, 03:40:50 AM »
Some of these engines work as low as 35degs C (body heat), even a lot lower if you cool the top plate with say an ice cube or a small pot containing cold water, or even ambient if you stand the engine on a cool pak, they work on differential temperatures.
So I am not looking at anything where a kiddy could put it's hand on and be burned.
I will be buying and experimenting with a cheap vivarium mat for the time being, and take it from there.
Skype - bandit175
