Gallery, Projects and General > How do I??
Removing a hex bolt that has been rounded
<< < (6/6)
Sorekiwi:
Now, I would have thought you'd put it in your fancy cnc controlled rotary table and cut a new hex on it!
raynerd:
HAha ... I would, but firstly it was so rounded that I`d have to take it down significantly to get a good shaped bolt on it. Secondly, I use to think people were really lazy for saying things like this but I`ve not had much shop time lately with work and such, so I`d much prefer to spend my time on one of my projects for the sake a £5 for a new one!
andreas:
Hmmm....Kvom said it :headbang:  I do that a lot on truck differentials and gearboxes draining screws,and sometimes it comes out by hand(make sure its cold!!!) Something you have to be careful is the ground lead,if you don`t want to mess electronics on the bike....Ground as near as possible were you going to weld. It`s also wise to remove the battery and short the terminal cables together while welding :beer:
bry1975:
Are any of you chaps into cold heading bolts? :D
doubleboost:
Whenever i weld on a vehicle i put a surge protector across the battery (saves blowing ecu,s)
On most modern stuff you are going to run in to trouble disconnecting the battery
Navigation
[0] Message Index
[*] Previous page
Go to full version
