Author Topic: Removing a hex bolt that has been rounded  (Read 25058 times)
« on: November 07, 2010, 12:51:19 PM »
Hi guys
Hoping someone could help me out. I`ve got a motorbike, a CG125 to learn on a few days ago. I went to change the oil today and found that the large 24mm hex bolt which is the plug has been properly rounded off and my socket just slips off when I exhurt some pressure on it - it also seems pretty stuck on as well which doesn`t help. Has anyone any suggestions as to methods of removing it? I`m struggling to find a replacement so ideally I don`t want to destroy it removing it as I may need to use it again.
Offline mklotz
  • LA, CA, USA
Re: Removing a hex bolt that has been rounded
« Reply #1 on: November 07, 2010, 12:54:11 PM »
Vise-grips (I think you lot call them Mole-grips or some such).
After you get it off stick it in the mill and carve some flats into it to fit a standard wrench size.
Regards, Marv
Home Shop Freeware
Offline bry1975
    • http://www.satintime.co.uk
« Reply #2 on: November 07, 2010, 01:02:22 PM »
If it's safe can you heat the part up?
Regs
Bry
Offline kwackers
« Reply #3 on: November 07, 2010, 01:19:07 PM »
Order a new bolt. Couple of quid and the bike shop will have on for you within a couple of days.
Once it's here you can use whatever means you like to remove the old one.
« Reply #4 on: November 07, 2010, 02:15:47 PM »
Marv, already tried mole-grips and I can`t get them around the bolt because of the position it is in.
Bry, yea, I heard heating up worked so I took it on a long spin and it was really hot, still wouldn`t move. It isn`t just the fact it is locked on but I can`t get any torque, my socket just slips off due to the rounded hole.
Kwackers - I think that is my best bet but I`ve googled and can`t find them for sale. I don`t know what thread it`ll be on them - it is certainly a 24mm socket - does that directly tell me the thread on it. I have the haynes manual infront of me and can`t see anything about the thread. I don`t fancy conceeding and taking it into the garage. The hole point of me eventually going for a cg125 was because it would cost me nothing other than parts in terms of maintainince as I`d do it all - I`ve clearly fallen at the most simplest of hurdles!
If I can get it off like Marv said, I can mill it down to a standard socket size...it is just getting the ba!$$!!d off!
« Reply #5 on: November 07, 2010, 02:25:23 PM »
Poke two holes in it, then lash up a pin spanner to fit. Either from flat or on the end of some round bar.
If it's knacked you'll need a new one anyway, Cannot imagine it's impossible to get bits for a CG125. The planet was knee deep in 'em.  :thumbup:
Dave BC
Offline kwackers
« Reply #6 on: November 07, 2010, 02:28:12 PM »
Just ring a bike shop and order one - or (heaven forbid) call in! If you're going to do your own maintenance then ringing bike shops is probably a skill you need to learn. ;-)
Assuming it's the bolt that holds the oil filter in place you want the real McCoy anyway. Chances are it's not an ordinary bolt, probably has oil ways machined into it.
Once you have one to hand there are a number of things you can do (depending on access). You could drill it and use a 'tommy bar', you could do my usual which is to use a chisel at an angle along with a small hammer and 'tap' it round (lightly!) or file some flats and use a spanner. You could even file the head off to release the oil filter and then use mole grips on the shaft. Have a look in the Haynes manual to see what it looks like under there.
« Last Edit: November 07, 2010, 02:31:06 PM by kwackers »
Offline Sorekiwi
« Reply #7 on: November 07, 2010, 02:34:18 PM »
If you are using a 12 point socket, you might try a 6 point socket.
Another thought, a 15/16 socket is 23.8mm, maybe you can tap that onto the plug?  Again a 6 point would be better.
Mike, expat Kiwi in NE Ohio, USA
Offline Ned Ludd
« Reply #8 on: November 07, 2010, 02:43:32 PM »
Hi Chris,
Have you got a six point socket or is it the more usual twelve point? The six point, by this I mean it has just a hexagon hole which fits the bolt, is much better for gripping soft-ish alloy caps like an oil drain plug.
Buy a new one, any Honda shop should be able to get one next day or perhaps the day after, then carefully tap the old one around with a hammer and chisel/punch. When using this method, on the underside of an engine, it is all too easy to try to turn the thing the wrong way, especially if you are new to the game. I don't wish to impugn your abilities but are you sure you are in fact un-doing the cap, remember if it under the engine it appears, from the top, to go he other way.
Ned
PS sorry for overlap of six point sockets.
Leafy suburbs of NW London
« Reply #9 on: November 07, 2010, 03:04:54 PM »
Most Honda shops should have a replacement without having to order you one.
You may end up either having to spend some money or dropping the engine the engine to get that bolt out. Personally, I would get some sockets that are designed to remove rounded bolts. They come in handy... I have 2 sets, each a different style. The first is designed to grip the bolt on the flats.
IE:
Grip-Tite Sockets
The other set I have, is a reverse screw socket. Not sure of the brand, I will check them and see. The principle is, as the socket spins on the head of the bolt, the socket tightens its grip on the bolt.
  • Country: nz
« Reply #10 on: November 07, 2010, 03:17:02 PM »
How about some way to stop the socket jumping off?
For example, if the bung is on the bottom of the bike pack some blocks of wood under there until the weight of the bike is holding the socket on,  if the bung is on the side of the bike you might be able to lean the bike against the socket which in turn is being braced by a handy fence post?
Play it safe and do not let the bike fall over!
Offline Ned Ludd
« Reply #11 on: November 07, 2010, 03:21:34 PM »
Very interesting link that, but I still like the right size spanner or socket as first choice.
I used similar technology to make a tool for removing seized pistons in motor-cycle brake calipers, the harder you turn the harder it grips and once you get the piston turning you can pull too.
Ned
Offline jim
« Reply #12 on: November 07, 2010, 04:07:15 PM »
had the same trouble with my CG125, (i'm putting a sidecar on it :lol:, its a long story)
get the engine warm, give it a "tap" square to the face. then a good tap with a chisel. to turn the cap. mine came undone ok.
they don't need to be done up too tight, if you reuse the cap (i did) with a new o ring on it i just nipped it up and all is well again!
Offline Bourne Bill
« Reply #13 on: November 07, 2010, 07:39:19 PM »
you can try putting a piece of shim stock over the flats on the bolt, and force a socket over it. It has worked for me in the past........
Life is short, eat dessert first...........
Offline kvom
« Reply #14 on: November 07, 2010, 07:43:57 PM »
Another idea is to weld a good bolt onto the rounded one.
Offline j45on
« Reply #15 on: November 10, 2010, 04:29:24 PM »
Did you get the sump bolt out then ?
 :worthless: of your new bike
Jason
« Reply #16 on: November 10, 2010, 05:18:51 PM »
Hi Guys, yes sorry I never replied. I`ve been a bit busy but I did read all your suggestions. I managed to remove it last night, I filed it down to fit a 22mm spanner and now it works fine. The alloy it is made from is like cheese, no wonder someone had rounded it. Believe this, it is so badly rounded that even taking 1mm off each side to get the 22mm bolt, it still looks a mess with rounded edges slight but the flats are good enough to get a good spanner onto. I`ve had to fit it back onto the bike as I need to use it but I don`t know if I can actually salvage it, I think the truth is I need a new plug. To be fair, with a good spanner it works just fine but it looks a mess. I could make one, but I don`t know what the thread is?
Thanks for all your advice, I really appreciate it.
Offline bry1975
« Reply #17 on: November 10, 2010, 08:12:50 PM »
« Reply #18 on: November 10, 2010, 10:51:33 PM »
Don't know bu663r all about bikes other than they fall over easy!
but I do know "Mr.z"  at the end of that link has a comic way with the language   :lol:
« Reply #19 on: November 11, 2010, 07:03:23 AM »
Booo --- I can`t read it - content blocked at my work!
« Reply #20 on: November 11, 2010, 07:05:00 AM »
Just to add - ordered a new one, only £6 including postage and a new washer. When I said it was a soft alloy, I have since found out it is aluminium! No wonder it rounded, I`m guessing is was done by the dreaded adjustable but still, ally not the best material for a nut surely?
Offline kwackers
« Reply #21 on: November 11, 2010, 08:00:51 AM »
It's not a structural part - it's just meant to stop the oil falling out. Just don't swing on it too hard.
Offline 75Plus
« Reply #22 on: November 11, 2010, 09:36:06 AM »
I spent several years in the automotive service industry. One of the the most puzzling things was why the oil drain plug was a constant problem. It appears that most "Do It Yourself" (Shadetree on this side of the Pond) mechanics thought that the drain plug was the ONLY thing that held the engine together and had to be TIGHT. There was even one "After Market" supplier that made an assortment of over sized, self tapping, plugs to replace the inevitable stripped ones. They were marked as #1,#2 ect. oversize.
Joe
Offline jim
« Reply #23 on: November 11, 2010, 11:49:05 AM »
glad you got it sorted :clap:
« Reply #24 on: November 11, 2010, 11:53:19 AM »
Pleased you got it sorted
This is a common problem in the motor trade
Easiest way is to weld a big nut on to it the heat of welding helps
