Another 4" CNC rotary table
HS93:
yes me to a full kit or whatever you can do
thanks for your offer
Peter
z3t4:
Jeez! A bloke spends a few days away with his Jaffa cakes and returns to carnage!!
I got this lot from Farnell in the summer, waiting for the cold weather. The part numbers work,
* means I had some in a bucket somewhere. And the formatting's crap. Sorry a bit better now :beer:.
Part Number Value Farnell Qty NotesC1, C233pF11417612C3, C4100nF14693104Decoupling -- spread liberally.C5470uF 25v elec 94512001VR110k Preset16898441Contrast controlR1 - R410k*4Keypad pull downsIC118F45297622301Pre-programmed with firmware.IC2780517555081And small heatsink.40 pin IC Socket42856691For PIC 18F452Xtal10Mhz16118561Keypad4 x 4 11712241(or 16 buttons)LCD 4line x 20*PCB Or stripboard construction.8 Pin SIL socket12188691Only if using Farnell keypad.Case Power supplyTo suit stepper/stepper controller. BeeperLS1Passive sounder11925131Q3BC33715743791NPN transistor (500mA IC)R54k7** D2BYV2714693711Any fast switch diode Sense/AckD1BYV2714693711Any fast switch diodeQ1, Q2BC33715743792NPN transistor (500mA IC)R8, R94k7** R6,7,10,1110k**
HTH
tumutbound:
I created a component list with Mouser a couple of weeks ago.. Total cost of everything except PCB is approx $US43 - plus shipping.
I don't know if Mouser is an option for UK based purchase but I can share the project file if anyone is interested.
I can do the same with Digikey if there's interest.
Update: $23 of that cost was for a 20x4 LCD. You can pick these up from a number of online sources for $10 - $12
As far as PCB go, I use pcbcart.com which is a Chinese based manufacturer. Prices are pretty good e.g. 20 off 100mm x 150mm double sided boards, silk screen cost $US144. Turn around of 12 days. Artwork must be provided as Gerber files.
There are also a couple of places that specialise in prototyping boards i.e. 10 boards, 100mm x 100mm double sided $US28 plus shipping. Add an extra $US10 if you want blue boards. ::)
I haven't checked the size of the driver board so don't know how useful this information is.
Brass_Machine:
I am not happy with direction this started to take. I am glad to see that it has gotten back on track.
So let's cool the hostilities. We are all adults here. This is Jason's thread... I am removing the posts that do not add to this thread.
Bluechip:
--- Quote from: John Stevenson on November 25, 2010, 06:27:16 PM ---Bogs,
If you are willing to use an old laptop or desktop computer I can supply everything except the table.
It will be a box with mains plug on, USB plug for the computer and a lead out going to a stepper motor.
You start the computer, start the program and this is what you see.
Does basically all a Division master does but not hand held.
John S.
PS Send photo of hairy arse.
--- End quote ---
Last line of this looks a bit .. er ... surreal now Eric :lol:
Dave BC
Navigation
[0] Message Index
[*] Previous page
Go to full version
