Author Topic: Yet another paddleducks engine build  (Read 39358 times)
Offline boatmadman
  • Located in Barrow in Furness, South Cumbria
« on: February 14, 2010, 04:13:41 PM »
I thought it was about time I put my mill to good use, so, after looking around and reading various threads I decided on a Bogstandard engine build.
So, downloaded the files, gave them a coat of looking at and, following his instructions as closely as possible, set to..... :proj:
with one exception, he recommends making a spare every time you machine something - so I am doing, but in this case its a complete spare engine!
My theory is, if I get a 50% success rate I will have one workable :dremel: engine!
Anyway, this pic shows cylinder blocks in CI, pistons and rods, top covers and bottom glands. Also is one brass block machined square for a crosshead, others not done yet. (the line on the block is a machine mark - to be polished out later)
Ian
If it works, take it apart and find out why!
Re: Yet another paddleducks engine build
« Reply #1 on: February 14, 2010, 05:12:08 PM »
Nice work Ian
I'm sure Bogs will be pleased to hear another engine is on the slipway.
Have fun
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #2 on: February 15, 2010, 01:51:31 AM »
Looking good there Ian :thumbup: that's a real good start made.
My paddleducks build has had a temporary halt called as a more urgent project came up ( redecorating & laying a new floor in the living room ), but I hope to get back to it soon.
Tim
« Reply #3 on: February 15, 2010, 03:24:17 AM »
You`ve got that away to a good start Ian!  :clap:
Good luck with the rest of the build.....  :thumbup:
Offline boatmadman
« Reply #4 on: February 18, 2010, 04:41:52 PM »
Can anyone suggest what grade of aluminium I should use for the block base plate, and where I might get it?
Thanks
Ian
Offline CrewCab
« Reply #5 on: February 18, 2010, 05:22:27 PM »
Hi Ian,
Glad to her your putting the mill to good use  :thumbup: ............. as for aluminium mine often comes from Fleabay and is usually specified by price rather than grade  :scratch:
I'm sure someone will be along with a sensible answer before long  :beer:
CC
Offline spuddevans
    • My Photo website
« Reply #6 on: February 18, 2010, 05:33:04 PM »
Thanks
Ian
I cant comment on what grade, but on thickness I asked about the same thing and got told This
Tim
« Reply #7 on: February 18, 2010, 06:20:50 PM »
Ian
In case it's any help, I have some 15mm thick 6082T6 which mills very well. ( I only know this 'cos it's printed on it ).
Afraid I don't know where to get it from, as I scrounged it some time ago.
I have some other Ally which is awful stuff, so there are probably some specs. that are not very suitable for machining.
Dave BC
« Reply #8 on: February 18, 2010, 09:13:58 PM »
6061 T6 is common around here. Then there is a plate called jig plate which is a softer grade of aluminum, 2024 I believe. Then there is the harder stuff 50 something or other. I know it don't help much, but I'd used 6061 since I have quite a bit of it. Unfortunatley it's in the USA.
« Reply #9 on: February 19, 2010, 03:36:13 AM »
Here's some basic info about aluminium grades, and a the machinability of some of them at least: http://www.merseymetals.co.uk/aluminium.html
I can also tell you that N8 seems to machine quite well, as that's what I've got tons of at the moment...
Offline boatmadman
« Reply #10 on: February 19, 2010, 07:59:02 AM »
Great stuff, thanks for the help.
 :thumbup:
« Reply #11 on: February 19, 2010, 09:18:54 AM »
Interresting specs. They say international, yet I don't see a spec for 6061 plate.
I've attached a pic of the 1/4" plate I have. It's just for point of interest.
« Reply #12 on: February 19, 2010, 10:36:39 AM »
Bernd - I believe 6061 is an ISO designation; but 6063 - I was told when I spoke to Mersey Metals last - supercedes 6062 which, in turn, superceded 6061. I presume the formulations are very subtly different, but I can't tell for sure.
If you want, I can ask a specific question or two of them on Monday, when I go to pick up a bit of steel I've ordered.
« Reply #13 on: February 19, 2010, 11:10:59 AM »
Good grief, what's up with you lot .. :scratch:
Took me about 30 secs. to find this ... not that I have any real interest ..
http://aluminium.matter.org.uk/aluselect/05_fabrication_browse.asp
I've selected the stuff I have on the LH column. sez 6082T6 is 'good' for machinability ..
Dave BC
Offline boatmadman
« Reply #14 on: February 21, 2010, 12:55:04 PM »
Managed to get a few hours in the workshop today. Spent 2 hrs figuring out how to mill a radius using the dro, then realised I wasnt taking into account the dia of the tool DOH!
Had one misshap, fortunately, no damage to the mill or tool, just some dints on the work piece oh and I escaped injury!
What happened, got my climb milling and conventional milling mixed up. Ripped the brass out of the vice and sent it across the workshop - lesson learnt! ( it was only a 0.2mm cut as well!)
Anyway, the pics show some brass hacked out of a length of round bar, first into rectangular blocks, and then into 2 croosheads - only 2 more to make now :thumbup:
« Reply #15 on: February 21, 2010, 12:58:22 PM »
Ian,
Hey we all make mistakes. Just hope you learned from it.  :thumbup:
Looks like your progressing along quite well. Wouldn't it be neat if you got both engines to run?
Keep up the good work.
Offline boatmadman
« Reply #16 on: April 03, 2010, 04:34:49 PM »
I got a day in the workshop today, so thought some steam engine work was in order.
I started out with a length of bronze as you see in the first picture, and after several hours of hacking, sawing, swearing, filing and drinking coffee, I ended up with the items in the second picture. These are the bearings for the engines, they are not quite finished yet, they need a cosmetic cut just to make them prettier.
Ian
« Reply #17 on: April 03, 2010, 09:20:25 PM »
Wow Ian. I'm going to have to try those five things you mentioned above and see if I can turn out such nice work.  :thumbup:
« Reply #18 on: April 03, 2010, 09:41:23 PM »
Ian
I don't know what kind of coffee you are drinking but I know that I want some! Mine sure doesn't give results like that.  :lol: :lol:
Offline spuddevans
    • My Photo website
« Reply #19 on: April 04, 2010, 02:29:40 AM »
Hey hey, very nice work there :clap:  Keep up the good work.
Tim
« Reply #20 on: April 08, 2010, 06:20:56 AM »
Yep, nice work Ian. I had the pleasure of visiting Bogs a couple of weeks ago and he showed me this engine running - very nice.
Offline boatmadman
« Reply #21 on: April 20, 2010, 03:50:22 PM »
Ok Fella's, I need advice.
Today I got some brass 2mm sheet for the bedplates, and a new toy, a slitting saw and arbor.
Now, having never used a slitting saw, can I grip the sheet in my vice and cut off a piece the size I want, holding it with, say, a pair of pliers as the cut finishes?
Or, if thats a no no, what do I do?
Ian
« Reply #22 on: April 22, 2010, 09:29:38 AM »
Boatmadman,  I have often been accused of being a bit lackadasical in the safety department, but I have done what you describe, only using fingers to hold the piece being cut off.  I wouldn't do it with steel particularly stainless, however for brass, I'd have no qualms, but I do have lots of scars on my hands, and my mother shakes her head and never wants to hear.  It will do a bang up job cutting off a piece of sheet with parallel edges, and without distortion along the cut, something of inestimable value with brass.  I don't know what you have for an arbor, but I have avoided multiple size arbors like the plague, not trusting in them keeping the slitting saw flat and tightly held, but have made a separate arbor for each size I need.  For what it's worth, that's my take.   :beer: mad jack
Offline boatmadman
« Reply #23 on: April 24, 2010, 04:03:16 PM »
I gave the bearings a nice cosmetic cut today, the first pic shows them with a set of crank web blanks.
The second pic shows one set of ten webs almost finished.
Ian
« Reply #24 on: April 24, 2010, 06:36:45 PM »
Nice work so far Ian. I am impressed. Very nice  :thumbup:
