Author Topic: Resistance Spot Welding,Arc Stud Welding Fundamentals  (Read 6320 times)
Offline PTsideshow
« on: August 06, 2008, 06:39:43 AM »
Miller student package deal. About a package deal that Miller has on their web site. I will go over the separate books and booklets purchase http://www.millerwelds.com/education/tools/
PDF's downloads http://www.millerwelds.com/education/bookspamphlets.html
Handbook for Resistance Spot Welding
by Miller ©2007
soft cover booklet
    * Safety Precautions
    * Introduction
    * Fundamentals of Resistance Spot Welding
    * Maintenance and Troubleshooting
If you have one of those hand held pincer style knocks offs or a real miller one this will answer some of the questions you have when you start out using it from why am I tripping the breaker each time to dressing the electrode points. If not it will answer the question can I use one, screen spot welding to frames and other sheet metal jobs.
By Miller
copyright© 2005
soft cover booklet
    * Arc Stud Welding SW) Guidelines
    * Stud welding Process
    * Weld Inspection/Trouble Shooting
They have given all the information on studs welding to steel tanks or plates. and charts and drawing in both booklets. I have an off brand that was given to me of a type of stud welder that is used for attaching the boiler lagging rivet/studs to the boiler and it pretty much follows the same information path as Millers.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
