Author Topic: Harrison L5 change gears  (Read 6258 times)
Offline slowcoach
« on: December 17, 2009, 03:29:20 PM »
Hi all, does anyone out there know what changes gears are required on a Harrison L5 to cut a 6tpi thread. I have no gear chart on the lathe to guide me   :scratch:  hence the plea.
 :thumbup:
Online mklotz
  • LA, CA, USA
Re: Harrison L5 change gears
« Reply #1 on: December 17, 2009, 03:46:27 PM »
I'm not familiar with the lathe but, assuming it has an Imperial leadscrew, it should be easy to puzzle out the required ratio.
Say the leadscrew has a pitch of N tpi.  One revolution of the LS will move the carriage 1/N inches.  To cut a 6 tpi thread, you need to have it move 1/6 of an inch for each revolution of the spindle.
Thus the spindle to leadscrew ratio needs to be N/6.  Any set of gears that yields this ratio should do the trick.
Regards, Marv
Home Shop Freeware
Offline Darren
  • N/Wales
« Reply #2 on: December 17, 2009, 03:54:11 PM »
There are a couple of downloads here http://www.lathes.co.uk/latheparts/page14.html that will serve you better than the original charts ...  :ddb:
Select the download suitable for your lathe and away you go ....  :thumbup:
Offline slowcoach
« Reply #3 on: December 18, 2009, 03:49:15 AM »
Thanks guys, I will have a go at that.  :thumbup:
