Home Base > Introductions
Hello From Central New York
<< < (2/2)
platypus20:
--- Quote from: chuck foster on December 12, 2009, 02:50:06 PM ---hello jack  :wave: welcome to the collective  :borg:
let's see some pictures of what you have been doing   :worthless:
chuck  :wave:
--- End quote ---
Most of the stuff I do, is pretty mundane, replacement air damper plates, new bearing supports or burner housing weld repairs. In the past I took a 1950 era Bridgeport mill machine and installed a 1986 Central Machinery mill/drill head on it, aka the Franken-Mill, a drill press adapter plate that allows me to lock the drill press vise just about anywhere on the drill press and a "transmission" that took the original 5 speeds on my Jet mill machine to 25 speeds. Other than that pretty mundane.
jack
Bernd:
Hi Jack,
Welcome to the collective.  :borg:
I'm west of you in New York. South of Rochester. Pass through Syracuse in the summer on the way to the Islands.
Glad to have somebody aboard the knows boilers.
Make yourselve at home. Many new projects and ideas exchanged here.
Regards,
Brass_Machine:
Hi There!
South of you...in Jersey... work in the city.
dsquire:
Welcome to MadModder Jack. It's great to have you aboard and I am sure that there will be questions come up about boilers that you might want to offer an opinion on. As you look around you will notice that it is not just engines but many kind of projects that the members indulge in. We look forward to your participation Jack.  :ddb: :ddb:
spuddevans:
Hi there Jack  :wave: welcome to the cube :borg:
Pull up a chair and join in where you can, dont forget the pics as  :worthless:
Tim
Navigation
[0] Message Index
[*] Previous page
Go to full version
