Author Topic: Glanze Indexable Set  (Read 8455 times)
Offline colin563
« on: October 11, 2009, 06:55:21 AM »
i have just purchased this 10mm set from ebay
im not 100% sure what each tool is
apart from the profile tool and parting tool
what it be posible for somebody to tell each one its use and best approach angles to use
sorry for all the daft questions  :hammer:
thanks colin  :clap:
Re: Glanze Indexable Set
« Reply #1 on: October 11, 2009, 07:15:00 AM »
Colin,
Almost all tipped tools already have the correct feed angle built into them, so they should be fed square in, either from the side (normal) or nose on.
Looking at the top row from left to right, LH cutting tool, for cutting left to right, RH facing tool, this is your normally used one, for facing off on the LH side, profile tool, next, no idea, but if it is a 60 deg angle, then maybe a threading tool, RH cutting tool, the one you will use the most, for cutting right to left, LH facing tool, for facing on the RH side, and lastly a boring tool.
« Last Edit: October 11, 2009, 12:42:34 PM by bogstandard »
Offline Darren
  • N/Wales
« Reply #2 on: October 11, 2009, 07:20:29 AM »
Just to add the bottom one looks like an insert parting tool, you'll be glad you have this one .....  :lol:
Offline CrewCab
« Reply #3 on: October 11, 2009, 07:57:32 AM »
Colin,
You might find This useful, have a look at Fig: 7-5  It's probably worth saving a copy of the whole document.
and Chronos, click on the pictures of the set as well  :thumbup:
« Last Edit: October 11, 2009, 08:03:44 AM by CrewCab »
Offline colin563
« Reply #4 on: October 11, 2009, 12:10:06 PM »
thanks for the replies
i understand index tools a bit better thanks to your information
ive also ordered a diamond tool holder Tangential type while i learn grinding angles
all i need then is a larger index type parting tool
and i should be sorted for most things
just go to learn what replacement tips for them seem to be 1000s of different types
thanks for your replies no doubt i will have a lot more questions to ask
thanks colin
« Reply #5 on: October 11, 2009, 12:11:54 PM »
Dave, page 7 in your link to what I think is the US Army training manual gives me the courage to mention something. I always thought that, as stated in the link and in my few books, RH tools are for cutting from right to left, towards the chuck. But John Bogs' labelling of Colin's set has it the other way round.
It's only a matter of names, not of function, but I'm confused :scratch: . That said, it doesn't take much to confuse me!
« Reply #6 on: October 11, 2009, 12:35:03 PM »
My fault Andy, I had them the wrong way around.
I will go now and put right my misinformation.
Offline jim
« Reply #7 on: October 11, 2009, 01:48:55 PM »
the two right and left hand knife tools look like CCMT 0602??  ??= tip rad ie 04, 08 etc
the the four other tools look like DCMT 1103??
