The Breakroom > The Water Cooler
Help ID the thingies?????
<< < (2/2)
John Hill:
--- Quote from: Darren on September 26, 2009, 07:10:56 PM ---They might be solenoids...?
--- End quote ---
They might be, they do seem to have an output shaft though.  Still, they could be rotary solenoids, we used to call them 'Ledex' motors,  usually had some sort of solenoid actuated ratchet and would rotate the output shaft one step for every input pulse.  I guess their function has been taken over in a lot of applications by steppers, but steppers require more control circuitry.
andyf:
Perhaps  :scratch: the blue box is a relay. And there's definitely a screwdriver in there  ::)
Bluechip:
PT seems bang on
Looks like two shaded pole motors, rh one with a reduction gearbox.
These things often normally run hot BTW, don't like 'em much.
Blue box thing is almost certainly an encapsulated transformer, it's near two black electrolytic capacitors, and the little square thing in front of the caps. could be a sil bridge rectifier, these bits are usually fairly close together as a PSU. A better pic. of the inscription will probably tell what the ac output is.
Usually load volts and VA rating.
What the black thing is with a gear on it is anyones guess from the pic. May just have a pancake motor on it. Speculation ..  ::)
Dave BC
Gerhard Olivier:
Should have explained a bit more
This is(WAS) a silicone putty mixer only outer casing broken
The small AC motor turned a small gear that turner the thing with the big gear ( big gear has a big magnet inbedded) and then i opened some bits to allow you to see in side.
Blue bit looks like a PSU 24v ????? both motors sais 230V
The bigger motor just spun the mixer
The smaller of the motors pushed the putty out slowly with a chain drive from that thing in first pic.
Is any of this usefull (remember im eletronically dislecsic!!!)
Gerhard
Bluechip:
Geroli
PSU is 24V @ 1.25A .. tranny will be higher volts output with no load.
It may well be the shaded pole motors are not rated for continuous use. Often, if they are a stock motor, this will be stated on motor. But, if they are made for the device specifically, it probably wont. Look for 'duty cycle' 'duty ratio' or similar.
Magnetic clutch looks handy, I would guess that probably works off the 24V ish DC ..
Dave BC
Navigation
[0] Message Index
[*] Previous page
Go to full version
