Author Topic: Machine Vice  (Read 33013 times)
Offline PhiberOptix
  • Adapt Improvise and Overcome
Machine Vice
« on: September 09, 2009, 11:48:12 AM »
This is the stage I was at Last night, basic stuff just milled out a large portion and a quick lick with a fly cutter
todays efforts
milled a slot in the side and center drilled, pilot drilled, and 8mm drilled and couter sunk the holes
milled a slot thru the base
then 5mm slot for running guides for the back jaw
this is as far as i got
SKYPE - GrimsbyDragons
Offline Andy
Re: Machine Vice
« Reply #1 on: September 09, 2009, 12:02:16 PM »
Looking good there.  :headbang:
That's a bit of a chicken and egg situation I suppose - helps if you've got a machine vice in order to make a machine vice. :scratch:
From probably the smallest, dampest and most untidy workshop in Bradford, West Yorks, England, if not the world..
Re: Machine Vice
« Reply #2 on: September 09, 2009, 02:13:22 PM »
That is starting to look very nice. Very professional looking. Keep up the build log!
Offline Darren
  • N/Wales
Re: Machine Vice
« Reply #3 on: September 09, 2009, 09:08:40 PM »
That's looking good, I'd be very interested to see the next stages... :thumbup:
Offline arnoldb
  • Windhoek, Namibia
Re: Machine Vice
« Reply #4 on: September 10, 2009, 02:13:24 AM »
Good going on that vice Andy  :clap:
 :beer:, Arnold
Offline NickG
Re: Machine Vice
« Reply #5 on: September 10, 2009, 03:38:07 AM »
Nice 1! Looks like you have  :proj:
I had one of those sort of vices many moons ago when I had a little sherline milling machine. The vice was brilliant! The machine was really accurate to give it its due but a just for small things! Didn't have a quill feed either which limited it a bit!
Nick
Offline PhiberOptix
Re: Machine Vice
« Reply #6 on: September 10, 2009, 12:59:27 PM »
turning the chamfer on the mushroom ring now need to drill it and part it off
Fly cut finish on back of rear jaw ready for drilling for locking mechanism
vice and parts for locking mechanism so far
(needs a longer caphead the biggest i have it too short)
once I get a longer caphead tomorrow i can give the vice a final fly cut
also thinking of making some alternative jaws in brass and stainless to fix to the existing ones
« Last Edit: September 10, 2009, 01:02:57 PM by PhiberOptix »
Offline NickG
Re: Machine Vice
« Reply #7 on: September 10, 2009, 03:05:55 PM »
Looks great, I found my vice very accurate and possible to get a high clamping force. good design as it's always pulling the jaw down as well.
Offline sorveltaja
Re: Machine Vice
« Reply #8 on: September 10, 2009, 03:46:59 PM »
Interesting project. Is that aluminum you are working on?
Offline PhiberOptix
Re: Machine Vice
« Reply #9 on: September 10, 2009, 04:12:26 PM »
Yes its Aluminium (Aircraft grade) It is to be used for Aluminum only until I make some Brass and Stainless Jaws for her
I may even have her anodised
regards
Offline NickG
Re: Machine Vice
« Reply #10 on: September 10, 2009, 04:13:19 PM »
Just wondering, how are you going to clamp it down to the table?
Offline sorveltaja
Re: Machine Vice
« Reply #11 on: September 10, 2009, 04:43:04 PM »
Is there spesific english language term for that kind of machine vice? I'm willing to build one(two, maybe three) small(er) versions for special purposes.
Offline PhiberOptix
Re: Machine Vice
« Reply #12 on: September 10, 2009, 04:51:37 PM »
I'm not lol, its going sideways in the vice it was made in
but...
I guess you can put longer pins thu the side holes and clamp down on them
or mill clamping slots in the ends & sides
I have seen blocks with pegs in the side just for clamping these down
but mines going in another vice so you adapt/mod your to you needs
regards
Offline PhiberOptix
Re: Machine Vice
« Reply #13 on: September 10, 2009, 05:07:37 PM »
I have only ever know them as a machinist's vice I am unaware of any specific name
I'm sure it probably has one I just dont know it, maybe someone could enlighten us
Re: Machine Vice
« Reply #14 on: September 10, 2009, 06:07:12 PM »
First ones on here
http://www.arceurotrade.co.uk/Catalogue/Workholding/Machine-Vices
I use a 1" one all the time for holding small stuff in my larger vices.
Offline NickG
Re: Machine Vice
« Reply #15 on: September 10, 2009, 07:04:35 PM »
I've seen them called tool makers vices before, think they are all ground, high precision things though.
Offline DeereGuy
    • D1 Adapter Solutions
Re: Machine Vice
« Reply #16 on: September 10, 2009, 07:41:22 PM »
Andy, nice project you have started there.  I am been kicking around building one also probably this fall when things slow down a bit.  keep up posted with your build..:)
Offline PhiberOptix
Re: Machine Vice
« Reply #17 on: September 11, 2009, 11:33:50 AM »
The starts of a small vice been fly cut
sorry go carried away and forgot to take pics
All done except the polishing
BIg brother and the little one
Offline PhiberOptix
Re: Machine Vice
« Reply #18 on: September 12, 2009, 08:26:51 AM »
and after a quick polish the baby of the two vices vice looks like this
Offline Darren
  • N/Wales
Re: Machine Vice
« Reply #19 on: September 12, 2009, 08:28:54 AM »
I do like your vices  :lol:
Esp the dinky one as I could do with one of those. I have some bars of cast steel I may have a go with......on top of all the other things I want to do of course....... :doh:
Offline sorveltaja
Re: Machine Vice
« Reply #20 on: September 12, 2009, 01:44:09 PM »
Is there some kind of T-piece, where tightening screw goes?
I have seen that kind of vices only on pictures.
Offline Gerhard Olivier
Re: Machine Vice
« Reply #21 on: September 12, 2009, 02:01:53 PM »
There is a plan on
http://www.projectsinmetal.com/free-metalworking-project-plans-toolmakers-screwless-vise-mill/
Hope this works / helps
Gerhard
« Last Edit: September 12, 2009, 02:03:31 PM by geroli »
Guernsey
Channel Islands
Offline PhiberOptix
Re: Machine Vice
« Reply #22 on: September 12, 2009, 02:37:16 PM »
yes there is a 'T' piece
All I used was a slice of round stock drilled and taped to match the locking cap head
and an off center hole thu the side for the locking pin (in this case a 1mm wire)
also there is a slot milled in the underside of the jaw to locate the slice into
to stop it rotating whilst putting the pin thu
There are plans for this vice but i did not use any
Hope this helps
The same method was used in her bigger sister
Offline sorveltaja
Re: Machine Vice
« Reply #23 on: September 12, 2009, 03:18:48 PM »
Thanks for the replies! They helped me to understand the mechanism :beer:.
Offline arnoldb
  • Windhoek, Namibia
Re: Machine Vice
« Reply #24 on: September 12, 2009, 05:29:54 PM »
Good going Andy  :clap: :clap:
And to think you groaned about Tiny being small  :lol: - come to think of it, have you found a compressor yet ?
 :beer: Arnold
