Gallery, Projects and General > Gallery
A high powered LED lamp
<< < (3/3)
Alan Haisley:
Tim,
The vender appears to have changed the SKU on the diffusers you used.
--- Quote from: spuddevans on August 19, 2009, 03:24:03 PM ---I got all the LED's, diffusers and the power supply from Dealextreme in hong kong, these are the links;
LED's : http://www.dealextreme.com/details.dx/sku.1302
Diffusers : http://www.dealextreme.com/details.dx/sku.2395
Power supply : http://www.dealextreme.com/details.dx/sku.14034
--- End quote ---
I think it is now 1917.
Now, to the reason I was reading your post in the first place: I was looking for clues on how to make the socket part of a ball and socket joint. Turning a ball is pretty obvious but how the heck does one turn the inverse of one?  :scratch:
It seems likely from your post that you must have done it.
Alan
krv3000:
well dun
spuddevans:
--- Quote from: Alan Haisley on January 31, 2013, 12:01:32 PM ---how the heck does one turn the inverse of one?  :scratch:
--- End quote ---
Actually I cheated, I drilled a hole very slightly undersize for the ball (about 0.1-0.2mm smaller) and then cut a slot with a hacksaw to allow a bit of spring to grip the ball. In fact I think I cut the slot 1st, which then allowed the steel to spring apart while drilling providing for the grip on the ball.
With a larger ball socket it would be possible to turn a slight concave inner section in the lathe I guess.
Tim
Bluechip:
I don't think industry is all that keen on internal spherical wotsits.
I've seen quite a lot of 'ball-joints' made by using a sphere between two shallow countersinks ..
Dave BC
No1_sonuk:
--- Quote from: spuddevans on January 31, 2013, 05:36:32 PM ---With a larger ball socket it would be possible to turn a slight concave inner section in the lathe I guess.
--- End quote ---
A Ball-nose end mill could work too.
Navigation
[0] Message Index
[*] Previous page
Go to full version
