Author Topic: Modified OKMO / Microcosm J07 Miniature Stirling Engine  (Read 6003 times)
Offline Jim Dobson
« on: October 03, 2024, 12:06:30 AM »
A very nice Miniature Stirling Engine it was a real 'dancer' across the table turning and spinning on its fuel tank so I cut and put some 4" x 4" timber in my 4 jaw chuck and bored it out to a tight fit on the lathe for the spirits tank and routed it, then stained and varnished the wood plinth. There was also a fairly significant secondary flame flareup from the spirits tanks breather hole when the spirits warmed up enough to create more vapour exiting the breather hole.  I extended with a small section of K&S aluminium hollow tube through the breather hole (drilled out slightly) and put a bend in the piping and flared it on the inside for a very tight and snug fit which completely solved the secondary vapour flame.
https://www.youtube.com/watch?v=_Z7A69P3fyo
