Author Topic: rotary table D1-4 reciever  (Read 40074 times)
Offline DeereGuy
    • D1 Adapter Solutions
« on: June 20, 2009, 02:45:41 PM »
My shop is a mess finally and I have swarf all over the mill and the lathe :D
My goal is to turn this chuck of 5.25 x 2 of aluminum:
into something like this that  will be mounted to my rotary table:
I have wanted to do this for a while now and all the postings that have been going on about rotary table adapters have spurred on my want to do one.
Currently I am at this point.
Once I get everything sorted out and proper dimensions figured out I will post the complete build with the plans as best as I can come up with them.  So far I have had a few minor screw ups but nothing I wasn't able to over come.  I won't be back in the shop today anymore because SWMBO has other more pressing things for me to do :(
Tomorrow however is fathers day and I have been notified that it is mine to do as I see fit. :beer:
Cheers all and I will keep you posted as I make progress
Bob
Note edited to modify the title to reflect it is for the rotary table. ::)
« Last Edit: June 21, 2009, 02:33:54 PM by deere_x475guy »
Re: D1-4 reciever
« Reply #1 on: June 20, 2009, 03:10:05 PM »
Bob,
Interesting project. :dremel:
Aluminum? :bugeye:
Aren't you afraid of putting bumbs and dings in it when changing chucks or is it going to be protected from such abuse?
« Last Edit: January 09, 2011, 11:42:53 AM by Bernd »
Re: D1-4 reciever
« Reply #2 on: June 20, 2009, 04:58:23 PM »
Hi Bob
I've found my RT/chuck mounting invaluable, for quick sets, you'll find it well worth the effort, look forward to seeing your set up develop.
Offline DeereGuy
Re: D1-4 reciever
« Reply #3 on: June 21, 2009, 02:33:26 PM »
Bob,
Aluminum? :bugeye:
Bernb
Bernd, yes aluminum, I had this on hand from a real deal I got on 4 - 8" pieces I picked up a couple of years ago.  Money's tight as it is for most of us so this is what I chose, right now I am calling it a prototype but it may very well come out totally usable if I don't cock it up some how.  Plus it is light and makes moving the rotary table with it mounted and the 5C collet chuck possible for me w/o a crane of some type.  The Bison 3 jaw and 4 jaw chuck's that I have will be another story.  I have already dropped it and have taken care of the first ding anxiety :bang:
Offline DeereGuy
Re: D1-4 reciever
« Reply #4 on: June 21, 2009, 02:44:34 PM »
Hi Bob
Hi Stew, I have some minor tweaking going on today to make the pieces fit together nicely.  At this point I don't see it being done today because as soon as the sun passes far enough to move it off the south side of the house I will be doing some sanding on the south side of the cabin to prepare it for another coat of maintenance stain.
It may not appear that bad in the picture but after 4 years of southern exposure I am getting some failure of the original stain.  It's not to bad of a job really this time around.  The original coat took me almost two summers to do the whole house.
Re: rotary table D1-4 reciever
« Reply #5 on: June 21, 2009, 02:46:41 PM »
Sounds like a plan then Bob. I can understand the finances being tight.
Ya, why didn't think of that, "prototype". Have to see if it'll work or not so why use expensive material the first time.  :)
« Reply #6 on: June 21, 2009, 03:15:30 PM »
Wow Bob
That looks like a lot wood to stain, don't let Bogs see it, as it'll give him nightmares you know what he thinks of wood
 :D :D :D
Nice looking house by the way.
Offline DeereGuy
« Reply #7 on: June 28, 2009, 10:20:45 PM »
Well I had a few hours in the shop today and got 1 pin fitted so I have a few more pics for everyone.  I decided I would make a hex head and use a socket to tighten the pins.
Here is a shot of the pin inserted into the reciever and turned so that the chuck can be mounted
Here is a shot of the pin rotated 90 degrees.
Once I get all thee pins finished I will tighten my 5c chuck down and measure the run out.  I am a little worried that the 90 degrees will not be enough to lock it and may have to reduce the dia of the pin where the interferance fit is.
I will keep you all posted on my progress as I get time.  The logs are now ready to stain but we have 3 days of rain coming so I may get a few hours over the next 3 evenings to work on it a bit more.
« Reply #8 on: June 29, 2009, 01:04:20 AM »
Progressing well Bob
 :thumbup:
Offline DeereGuy
« Reply #9 on: July 03, 2009, 05:11:22 PM »
Tomorrow is a holiday here in the States and the company I work for gives this off to us.  Since it fell on a weekend day they gave us today off. :D
Since it is my birthday and we have a threat of rain I didn't do any staining on the cabin today....instead I made some great progress in the shop on the reciever.
I was having some trouble getting things concentric.  After bluing up the register I found that when I tightened up the receiver pins the chuck would be pulled slightly off center and would not let the chuck sit tightly on the face.   :bang:  Ok...so back to the mill, find center again on open up the holes about .010.  PERFECT!!!!.... Before doing this I noticed that my 5C collet chuck was the only chuck that would fit fairly well in the holes.  The rest would not drop down low enough because of binding.  What I found after checking the bores for the pins on the lathe reciever that they were made for a very sloppy fit.  Now I have just slightly over .001 TIR with it mounted in the 4 jaw and when I finally fitted it to the rotary table I have the same results with a .75 dia rod held in the 5C collet chuck.  I am more than pleased with this as I was shooting for no more than .003.
Here is the 5C collet chuck mounted to the reciever.  It measured .001 + TIR here.
Here it is mounted on the rotary table with the same TIR.
Here are the other D1-4 chucks and face plate mounted on the reciever:
Obviously the height will be a problem for some, luckily I still have plenty of room left and now I can mount any size d1-4 chuck to the rotary table.
I still need to make the detents for the pins so that it is easier to locate where the pins are set to remove the chuck,  I have been kicking around the design of the pins quit a bit with circlip via skype and I will be cutting a grove all the way around the pins.  Spot drill where I want the detent, then use a metal ball and spring with a grub screw to push the ball into the detent.
Crap-O-Cad drawings to follow. :beer:
« Reply #10 on: July 03, 2009, 05:22:37 PM »
I can see that little lot becoming very useful...nicely done..... :clap:
« Reply #11 on: July 04, 2009, 01:03:39 AM »
Nice Job Bob  :thumbup:
Thats given you plenty of options for mounting work on the RT
« Reply #12 on: July 04, 2009, 02:57:27 AM »
A very nice conclusion to your project Bob.
As you most probably know, I am a great believer in adaptable tooling, especially if it extends your repertoire by being able to mount it between machines.
A real nice job.
« Last Edit: July 04, 2009, 03:57:33 AM by bogstandard »
« Reply #13 on: July 04, 2009, 03:39:38 AM »
VERY nicely done Bob!  :clap: :clap:
« Reply #14 on: July 20, 2009, 11:51:48 AM »
Dunno how I missed this one. I have to do something similar... Lots of good ideas here.
Offline DeereGuy
« Reply #15 on: July 20, 2009, 12:04:36 PM »
Thanks Eric a lot of R&D went into this one figuring out all of the dimensions.
« Reply #16 on: July 21, 2009, 04:29:34 AM »
Bob,
That is really good, be it's dead useful.  :thumbup: If I get a rotary table I would need a threaded adaptor for my lathe chuck, not sure how i'd go about making that.
Stew, how does yours mount?
Cheers,
« Reply #17 on: July 21, 2009, 04:55:34 AM »
Its held on witha 74mm register and four bolts through the back same as my lathe, the adaptor plate is held to the RT with a M2 taper with a cap screw up the back.
http://madmodder.net/index.php?topic=1330.0
Hope this helps
Offline DeereGuy
Re: rotary table D1-4 reciever (Plans are free just PM me.)
« Reply #18 on: November 20, 2010, 09:48:42 AM »
All,
I have the plans I am giving out to the forum members.  Just PM me and I will send you the set.  All I ask is that you use them for personal use only.
Offline DeereGuy
Re: D1-4 reciever
« Reply #19 on: January 08, 2011, 10:20:10 AM »
Bob,
Aluminum? :bugeye:
Bernb
I know this is an old post but I thought I would show what this part would look like after being in continual use for the last year and a half.  Weston Bye anodized this for me in August of 2009 and this is what it looks like today.  Surprising what protection a good anodizing will give.
This was the first version and below is what I have just finished.  This one takes the OEM camlock pins that can be ordered from various suppliers when the campin wears.
« Reply #20 on: January 09, 2011, 11:44:26 AM »
Ok, I'm convinced. (I don't think you've done any work with them  :lol: ) They still look great.
Offline ieezitin
« Reply #21 on: January 09, 2011, 12:50:29 PM »
What a great mod.
Great looking piece of equipment and shows quite nicely the benefits of anodizing. And by what I have read here it’s not that unachievable for most of us in our hobby shops.
Bob thank you for showing us.    Anthony.
Offline DeereGuy
« Reply #22 on: January 09, 2011, 03:07:54 PM »
Bernd thanks!
Anthony,
I have changed a lot of things since I first tried this myself last June.  I am now using a CC powersupply, commercial black dye, and nickle acetate for sealing.  The black part was anodized at 12 ASF and the tank temp was 75 - 78 degrees.  My tank mix is 1:1 Napa Battery acid to distilled water (5 gallons total).
« Reply #23 on: January 09, 2011, 04:29:37 PM »
Bob, quite right anodising is a great surface protection. We use it at work for components that have to be stored / used in extreme conditions. We put stuff through salt spray tests and it holds up really well.
Nice work there, Nick
Offline DeereGuy
« Reply #24 on: January 09, 2011, 04:45:29 PM »
Thanks Nick,
It's been a real learning experience.  I am thinking about adding a small chiller for the 5 gallon tank.  Now that I am shooting for 12 to 15 ASF it will be harder to keep the tank cool this summer.
