Gallery, Projects and General > How do I??
Is this a tool?
<< < (2/2)
AdeV:
Would a window key fit - the type used to unlock some double-glazing units?
https://www.trulypvc.com/window-door-parts/window-handles/window-keys/wms-kb105-window-key?gclid=CjwKCAjwlovtBRBrEiwAG3XJ-y6ojqjWGL3z_UXDpK2cB0nvl_qNsgPznrw2ZNX3WVGWARfdmwynrxoCNi8QAvD_BwE
Might need a spot of filing to make it fit?
RussellT:
It reminds me of the sort of fitting you used to get on multi purpose screwdriver bits, where you had a choice of blades to put in the handle.
shipto:
--- Quote from: AdeV on October 13, 2019, 12:50:25 PM ---Would a window key fit - the type used to unlock some double-glazing units?
--- End quote ---
Thank you but I have sorted it now.  :D
kayzed1:
So what where and when then :clap:
shipto:
--- Quote from: kayzed1 on October 13, 2019, 07:09:37 PM ---So what where and when then :clap:
--- End quote ---
Sorry rushed that reply because wife wanted to get on pc. Its a little embarassing actually but I saw the slits and assumed it was screwed in but it wasn't  :doh: it was actually held in by a hidden pin which you have to take the shank off to see. Not entirely sure why it has the slits to be honest but I am guessing they help you get the housing out once the pin is removed.
Navigation
[0] Message Index
[*] Previous page
Go to full version
