Author Topic: The Artful Bodger cuts a Morse taper!  (Read 18612 times)
« on: May 21, 2009, 04:42:26 AM »
This is how I turned a Morse taper, for no particular reason I just wanted to test the procedure!
I centre drilled a scrap of steel and mounted a dead centre between centres, you can see what I mean.
Then I turned the compound to be approximately parallel to the surface of the dead centre..
..... and mounted a dial indicator on the compound (it had to be on the actual compound not the cross slide).
The next step was to wind the compound back and forth adjusting the angle of the compound until the dial indicator showed no movement over the length of the taper.
Time to cut some chips...
... I had to go very carefully taking only light cuts as the position of the compound prevented supporting the end of the work.  All cuts were made by advancing the compound being careful not to move the saddle or cross slide.  The cross slide was advanced at the beginning of each cut otherwise left strictly alone and actually locked for the last couple of cuts.
Time to taste this pudding  .......
... slipping on the MT5-MT3 sleeve that came with the lathe.
A perfect fit, I thought I was going to have difficulty getting it off!
No final adjustment needed at all, just a quick polish up with some emery tape. :ddb:
« Last Edit: May 21, 2009, 04:44:13 AM by John Hill »
Re: The Artful Bodger cuts a Morse taper!
« Reply #1 on: May 21, 2009, 08:52:58 AM »
A tit bit of info here.
The only true way to test a taper is to give it a light coat of some kind of marking compound and then ringing the two parts together. When pulled apart you will see if you have a true fit or not by the marking compound left on the other part. This would be the only way to tell if you have contact along the full length of the taper.
« Reply #2 on: May 21, 2009, 07:35:20 PM »
I am sure you are right Bernd and if I can lay my hands on some suitable marking compound I might just do that, meanwhile the two pieces do seem to have an incredible affinity for each other.
Offline rleete
« Reply #3 on: May 21, 2009, 08:27:52 PM »
If no marking dye is at hand, use a Sharpie marker.
