Author Topic: A bit of fun drilling holes  (Read 19264 times)
Offline NormanV
  • United Kingdom
« on: November 26, 2017, 09:22:47 AM »
I found this video on youtube.
I have some carbide drills from Dremel that are broken, here is a good one.
Offline NormanV
  • United Kingdom
Re: A bit of fun drilling holes
« Reply #1 on: November 26, 2017, 09:29:20 AM »
When the drill point breaks off they are not dissimilar from the drill shown in the video. So I thought that I would give it a go. The result was interesting. I set my drill on its highest speed and drilled away. Initially it seemed to go exactly the same as in the video. The metal heated up to red and the point of the drill started to enter the metal. Then the "carbide" tip sheared off and left me with a hole nicely plugged with a piece of carbide. It's a shame for a moment I thought that it was a process that I could use.
Offline NormanV
  • United Kingdom
« Reply #2 on: November 26, 2017, 09:30:36 AM »
Here's a shot from the underside, sorry about the focus but you can just about see the point of the drill where it penetrated.
Offline NormanV
  • United Kingdom
« Reply #3 on: November 26, 2017, 09:33:38 AM »
And here is what happened to the drill.
Probably the wrong sort of carbide!
It's a pity, it could have been useful.
  • Country: nz
« Reply #4 on: November 26, 2017, 01:59:09 PM »
Seems like an excellent way to make holes for threading in thin stock.
« Reply #5 on: November 27, 2017, 01:08:07 AM »
Just looking at the hole finish reminded me of a trick the fitters used at work to flare the end of nylon tubing. They simply spun a shaped piece of steel in the portable drill to flare the end of the tubing. Friction did the melting of the nylon.
   Yarn was then blown through the 20odd feet tube to the needle head of carpet tufting machines. Think sewing machine with maybe 2000 needles and no bobbin.
    So, the holes as in the video, would work where one needed to pass cable / rope through a plate without a rough lead in, the underside though would need some work.
Offline Nicolas Hulme
  • What's this for?
« Reply #6 on: January 11, 2018, 02:24:05 PM »
I think the bit in the video was at least 1/4" diameter, thermal mass and conductivity might make the difference.
No list of equipment, it wouldn't fit ;-)
« Reply #7 on: January 23, 2018, 04:28:26 AM »
  Hi Norman
                    I seem to recall seeing something similar, where a cobalt drill was used.
