Author Topic: Repeat-o-meter  (Read 26137 times)
Repeat-o-meter
« on: June 28, 2017, 03:33:16 PM »
Revised video!
Here is a video about a Repeat-o-meter that I have just built. it is for checking surface plates for hollows in the surface. This build is directly related to the 91cm x 91cmx 15cm granite surface plate that I just bought in preparation for scraping and the Richard King Scraping class in December! I have also been following a Tom Lipton John sanders collective build of the same tool. i realise that I didn't give an explanation about why I used the lathe to grind the feet flat, I don't have a big belt sander or a surface grinder, so it was the only way to get all four "feet" flat!
[youtube]o8GU7hRp_Ec[/youtube]
Curious to have your thoughts, regards, Matthew
« Last Edit: June 29, 2017, 05:41:47 AM by mattinker »
Re: Repeat-o-meter
« Reply #1 on: June 28, 2017, 04:29:42 PM »
I'm looking forward to seeing this in the flesh in December Matthew.
(BTW I'm getting a 12 minute gap from 30 m to 42 m on playing your video)
Re: Repeat-o-meter
« Reply #2 on: June 28, 2017, 04:46:55 PM »
Thanks Andrew!
Re: Repeat-o-meter
« Reply #3 on: June 28, 2017, 04:55:23 PM »
Ooops!
I've made a mistake in the editing, thought I'd checked it through! So I'll swap out the the bad for the good video as soon as I can redo the mix!
Sorry about that! regards, Matthew.
Re: Repeat-o-meter
« Reply #4 on: June 28, 2017, 05:33:04 PM »
VERY nice!
Thank you for showing. I found the mentioned first part, but haven't seen the second part yet.
Re: Repeat-o-meter
« Reply #5 on: June 28, 2017, 06:17:14 PM »
Thanks Pekka, re-editing, compiling, will repost as soon as i can reload up to youtube!
Regards,matthew
Re: Repeat-o-meter
« Reply #6 on: June 29, 2017, 05:45:17 AM »
VERY nice!
Pekka, I've swapped out the video for the complete version, it's not very different, no blanc space at the end and two shots of the finished painted item at the end.
Re: Repeat-o-meter
« Reply #7 on: June 29, 2017, 05:48:43 AM »
Hi Andrew, I've put up a corrected version! Its not very different, no empty space at the end and two views of the finished painted item!
Looking forward to using it in December! Regards, Matthew
Re: Repeat-o-meter
« Reply #8 on: June 29, 2017, 07:29:36 AM »
Very smart Matthew - it just needs a nice polished oak plush lined casket with brass hinges and lock  :wave:
Re: Repeat-o-meter
« Reply #9 on: June 29, 2017, 07:33:17 AM »
I agree with you about the case, but it might well be painted plywood with green felt inside (both in stock!).
Re: Repeat-o-meter
« Reply #10 on: June 29, 2017, 08:48:11 AM »
Looks very nice Matt!  :beer:
One thing I missed seeing in the video is the Repeat-O-Meter in use on the surface plate you wanted to check with it at the start. How is it used, and was the plate flat?
Also..... sorry I'm not familiar with this tool..... if the balls are pressed in, how does the gauge end move up and down? Wasn't there a ball under that one?  And if the two stabilizer bars on the side are loose, what do they do -- or do you tighten them up?
I'm sure there are answers to all this, once you own one. But your video is the only thing I know about it!  :clap: :clap:
Re: Repeat-o-meter
« Reply #11 on: June 29, 2017, 09:27:30 AM »
i hadn't tried it when I filmed it, i thought I'do a video of mapping out the plate to follow!
The steel balls are pressed in and then ground flat, I finished them with wet 'n dry abrasive paper, once the balls were nice and smooth, I made a flexion by drilling a hole close to the bottom edge and slitting from the top down into the hole, leaving 1.2mm+/- so that the single ball/foot under the dial gauge can move up and down (within the elastic limit of the flexion!) whilst the three that remain under the mass of the body sit on a flat area of the surface plate. Them two "floppy" bars on the side are there to stop the lower front bar from "drooping" as there's nothing there to support it but the flexion. I think that these are more of a safety feature than anything else! I included a link to a Tom Lipton video that explains the us of the Repeat-o-meter
More coming, regards, Matthew
Re: Repeat-o-meter
« Reply #12 on: June 29, 2017, 10:13:50 AM »
Thanks Matt!
So the ball under the gauge is not pressed into place like the others, but is free to move up and down? And the side bars effectively put a limit on the upper and lower range of movement of the indicator -- hope I have that right?
Re: Repeat-o-meter
« Reply #13 on: June 29, 2017, 10:20:24 AM »
Thanks Matt!
So the ball under the gauge is not pressed into place like the others, but is free to move up and down? And the side bars effectively put a limit on the upper and lower range of movement of the indicator -- hope I have that right.
Nope! All four balls are pressed in, there is a flexion that is situated next to the two central balls, this allows the 20 x 50mm bar to bend near the middle, three of the balls under the heavy end provide a reference point, the remaining ball is under the dial gauge indicator. The side bars are there to stop the flexion bending too much and going beyond it's elastic limit!
Re: Repeat-o-meter
« Reply #14 on: June 29, 2017, 10:24:31 AM »
Nope, the upper part is (semi) rigid beam, that screw disc is only for adjustment.
The lower body is split half - there is a flexure (hole cut free from other side). All balls are rigidly attached. Three balls support the back of the meter and this "beam" on the top. Front part is sort of tailgate, this flexure allows it to follow countour of the surface plate.
Those loosely attached arms on the side work exactly the same way that tail gate keepers on pick-up truck. Prevent that part from dropping down when the instrument is lifted.
Purpose of the balls is to give a defined contact, when flat is not flat enough - you can describe a plane with three points, then you fourth somewhere and indicate how much it it is different.
Hope this helps,
*Nope, was to VT---- :lol: Matthew beat me just narrowly :wave:
Re: Repeat-o-meter
« Reply #15 on: June 29, 2017, 11:18:49 AM »
Okay, got it!
Or as we used to say,
Click.
 :lol: :lol: :lol:
Re: Repeat-o-meter
« Reply #16 on: July 16, 2017, 05:51:49 AM »
Here is a video about using the Repeat-o-meter, a little fuzzy in parts. I'm slowly getting the hang of this video stuff!
[youtube]wG6sJuhZlUs[/youtube]
Re: Repeat-o-meter
« Reply #17 on: July 16, 2017, 08:43:23 AM »
Nicely shown Matthew - I look forward to seeing the result of you sliding it over my 4x8 foot surface table when you come in December - I've no idea how good or bad it is  :scratch:
Re: Repeat-o-meter
« Reply #18 on: July 16, 2017, 08:52:55 AM »
Andrew,
Looking forward to it!! If somebody has a good long straight edge or maybe I can find or make on by then, I could make a "Planekator"
regards, Matthew
Re: Repeat-o-meter
« Reply #19 on: August 25, 2017, 01:15:04 AM »
Matthew
Your post and videos have been very inspirational and informative. To the point that I'm starting to build my version this week-end.
I think I have most figured out, only thing is that I have question is the flexure.
What is the thickness of your felxure (isthmus) on that sole plate?
How do you feel about it? I have 20*50 mm hot rolled steel and that is going be the sole plate.
Re: Repeat-o-meter
« Reply #20 on: August 25, 2017, 04:24:22 AM »
Pk,
I'm glad it's useful!
the "flexion" is 1.35mm. unlike the Rahn version, I drilled and reamed a hole for the flexion. I built mine without known dimensions,  so I finished up with one that is a little on the long side which means that it is a little more sensitive! the standard Imperial one is 5" from middle feet to measuring foot but there is a metric version which is 100mm. I used cold rolled for the base plate (I had it!), but hot rolled would be fine.
Re: Repeat-o-meter
« Reply #21 on: August 25, 2017, 06:12:06 AM »
Thank you very much.
I was eyeballing and estimating the Rahn version, but based on my past experience I very much prefer drilled/reamed hole to terminate such a cut.
I'm drawing parts based on 100+100 spacing. Bit torn between ballbearing balls pressed on tight holes (I have a fitting drill) or going trough unused circular inserts for lathe/mill. I have proper screws, drills/taps. Might be easier that way.
I have very nice Mitutoyo 2109S-10 0,001 mm resolution  indicator, but reading is a bit tight and i doubt that this would benefit that much linearity....very tempted to use cheap 0,001 mm resolution dial on this one.
Hope that this flu does not get worse. This might be just the right weekend project.
HRS is 20*50 mm and then I have some 5*50 mm for spacers. Can't find any 10(or 12) mm *50 mm for DTI arm and other parts, should hit junkyard, but it is closing early today.
Re: Repeat-o-meter
« Reply #22 on: August 25, 2017, 06:24:00 AM »
Pekka,
I have found reasonable 0.001mm indicators on eBay, I suspect that people don't notice the extra "0", they usually go for the same price as the .01mm, between €14 and €18 without shipping!
Re: Repeat-o-meter
« Reply #23 on: August 25, 2017, 06:28:09 AM »
Good to know. However many does not ship here. Bu not a bigie, because I have one cheap extra that is close to same size than the Mitutoyo.
I tried to read your answer carefully, I got the impression that I could try a tad thicker flexion that 1,35 mm you had?
Thank you,
Re: Repeat-o-meter
« Reply #24 on: August 25, 2017, 03:21:36 PM »
1.35mm seemed on the thick side to me, but it worked well. I think it's important to remember it's in the flexible range of the metal. The two limiting bars on the side are intended to keep the flexion in the limits of flexibility, mine are a bit slack, but it isn't a worrying amount of movement. The actual movement that I've found on my surface-plate is less than 0.01mm, so you can really limit the movement!
regards, Matthew
