Author Topic: Wilson's Workshop Waffle  (Read 249619 times)
Re: Arboga Geared Head Drill tart up
« Reply #75 on: October 01, 2016, 01:28:16 PM »
Why, it will hold it down on slippery roads. Which reminds me, must go and collect a Harrison 140 from a school that I have bought.
« Reply #76 on: October 01, 2016, 01:50:49 PM »
You bought a school ?
That's got to be a first for this group.
Dave. :clap:
« Reply #77 on: October 01, 2016, 02:44:03 PM »
good one rob
« Reply #78 on: October 02, 2016, 07:15:49 AM »
Suppose  I better remove the lathe from the van now  :dremel:
I'd love to see how you achieved this amazing feat of weight transferance..... :scratch:
Like so John  :thumbup:
Walk in the park . :)
Anyone out there with a spare travelling steady they wish to part with ?  £££
« Reply #79 on: October 02, 2016, 07:29:08 AM »
I'm impressed.... :bow: :bow:
I used an engine crane to lift my lathe onto its stand off the floor.....and thought that was scary stuff....well done...Did you do this all by yourself or did you have help?
So onto the lathe, is it single or 3 phase?...
I've used the bigger version when I was at work, great machines...
« Reply #80 on: October 02, 2016, 07:41:28 AM »
Hi John ,cheers mate .
Aye all by ones self ,having help  can really be more bother than its worth ,a distraction . And getting good help is very  hard to fined , any way its not that heavy mate .
Yes three phase 7.5 Hp motor I think  :scratch: , should dim the lights a tad  :zap:
I very nearly bought the long bed version ,but at the last minute decided against .
« Reply #81 on: October 02, 2016, 08:10:54 AM »
So how you going to run it? Rpc? ( a big one!.....)
« Reply #82 on: October 02, 2016, 09:02:12 AM »
That's the plan John ,  I will be ordering a 10 Hp Transwave RPC in a week or so  :zap:
« Reply #83 on: October 02, 2016, 06:10:47 PM »
Hi Rob, looks like its all happening  :thumbup: Colchester looks in good nick, looks like Newall DRO to, is the tool post S2 Dixon type ? Canny jack and hoist work getting it out the van mind, do you still have the other Colchester too ?
  Looks like you will be kept busy in the dark nights moving everything about. Are you going for new Rotary converter ?
  Cheers Mick
« Reply #84 on: October 03, 2016, 01:24:59 AM »
Yes I still have the other Colchester lathe  :dremel:
« Reply #85 on: October 03, 2016, 02:30:00 AM »
What hapened to the drill ?
« Last Edit: October 03, 2016, 10:22:09 AM by awemawson »
« Reply #86 on: October 03, 2016, 10:09:11 AM »
Still in the same state that I left it  :lol: , thread has wandered slightly  :Doh:
This thread needs a rename   :coffee:
« Last Edit: October 03, 2016, 10:21:47 AM by awemawson »
Re: Wilson's Workshop Waffle
« Reply #87 on: October 03, 2016, 10:22:48 AM »
Thread title re-named at Rob's request
« Reply #88 on: October 03, 2016, 11:57:24 AM »
Cheers Andrew  :clap: :clap:
« Reply #89 on: October 06, 2016, 11:07:17 AM »
Evening Lads
I picked up another bit of kit for the shop today , something I have been after for some time , a 10" pedestal grinder  :dremel:
Its a ye oldie Black and Decker , 3 phase , fairly beefy bit of kit .   My 6" bench grinder will be re homed in the other shop for sharpening tungsten electrodes and the likes .
Cheers Rob
« Reply #90 on: October 06, 2016, 11:24:40 AM »
Now, that's a proper grinder. A mate of mine used to have one similar in his old workshop. The wheels on his were about 2" wide. You can't beat having the mix of large circumference wheels and the added high inertial mass that goes with it.....OZ.
« Last Edit: October 06, 2016, 11:56:17 AM by Manxmodder »
« Reply #91 on: October 06, 2016, 01:43:57 PM »
Hi Rob,
Some time ago I posted about some refurbishment work I did on my Colchester Triumph 2000
http://madmodder.net/index.php/topic,10697.msg123432.html#msg123432
Yours looks to be a tidy machine
I am running mine from a VFD, 220v 3 phase so the motor terminals needed changing to delta configuration
There are a few issues on them that you need to look out for !!
The drive pulleys on the gearbox input shaft can wear (as on mine)
Some versions of the lathes have mains voltage to the control buttons, theres a gap below the chuck where swarf can find its way into the controls :bang: (mine now has low voltage controls)
Coolant finds its way easily into the apron gearbox, so when you use the one shot oiler its possible to pump coolant instead of oil
If you locate the lathe against a wall then you need to move the coolant tank to outside of the base so you can access it.
« Reply #92 on: October 06, 2016, 06:57:27 PM »
Love that the "MAX RPM" is unspecified!
A bit like "Max Headroom"
« Reply #93 on: October 06, 2016, 07:00:10 PM »
I can only assume it's MAD MAX
« Reply #94 on: October 07, 2016, 12:41:33 PM »
Hi Rob,
Cheers for the heads up John  :thumbup:
I will be giving the lathe a good check over when I get it into the workshop , I did notice the rear entry to get to the coolant ,I am still pondering that one as I will have the lathe up against the shop wall .
« Reply #95 on: October 07, 2016, 12:43:14 PM »
 :lol: aye it is a bit random Will  ,especially as its a fixed speed motor  :scratch:
« Reply #96 on: October 08, 2016, 09:12:24 AM »
Afternoon Lads
Well I picked up a couple more incidentals for the shop this morning , I had a wee run South to Pontefract and came back with these  :drool:
A rather tidy  10" Elliott rotary table for the Bridgeport .
and an  Auto reversing tapping head for the   Arborga drilling machine
Rob  :dremel:
« Reply #97 on: October 08, 2016, 09:34:32 AM »
Did you win the lottery then Rob  :scratch:
« Reply #98 on: October 08, 2016, 09:41:57 AM »
Nope just good at hunting out a bargain ,,,,,,,,,,or three  Andrew  :)
« Reply #99 on: October 13, 2016, 01:48:05 PM »
Evening Lads
A wee bit product review  :dremel:
I had a job on today that required the relocation of a couple of holes in a hydraulic pump flange and a bracket , pump needed to be rotated about 10 degrees so that the suction hose would not foul the engine sump .
The pump is located in a fairly confined space , so I cracked out the transfer screws I purchased wile  at Arceurotrade a few weeks back .
The kits come in two ranges  3mm - 6mm  &  6mm - 12mm
The M8 and M12 saved the day  :thumbup:   .
Each kits come with a driver to fit and remove the transfer screws .
Just the job  :dremel:
http://www.arceurotrade.co.uk/Catalogue/Measurement/Punches-Scribes/Transfer-Screws
