Author Topic: Gas Firing the Scott Vacuum Engine..........  (Read 29354 times)
Re: Gas Firing the Scott Vacuum Engine..........
« Reply #25 on: December 06, 2015, 03:55:30 PM »
@ philf.
 I fixed one of the 6mm long bushes, inside a 3mm dia piece of brass. Fixed inside a newly minted jet block......
The flames were only 1/2" high......  :(
Guess, it's the 6mm length, of the .12mm bore. But, they have plenty of larger sizes in stock!  :thumbup:
« Reply #26 on: December 06, 2015, 04:36:54 PM »
@ philf.
Hi David,
PM me your address - I'll send you an assortment. I had a look at them yesterday and, as you said, to my surprise the hole runs right through. I managed to get a 0.12mm wire through one which came out of the 0.14 bore section of the box.
Unfortunately, when I first opened the box a lot of them fell out so they're mixed up. I think the small end is tapered to match a broach. If I remember correctly you broached out a pivot hole, pressed in the small end, and snapped it off leaving the small end in the watch or clock plate.
I'm only guessing they make them by a drawing process. I can't imagine drilling a 0.12mm hole through 6mm of brass.
I inherited these amongst a pile of junk a mate dumped on me whilst he was helping a lady clear her house prior to moving. Her late husband had been a clock repairer. (I am perhaps being a little unkind when I say a pile of junk because there was a lot of good stuff amongst the rubbish. There was some incomplete diamond drilling equipment which he used for making diamond wire drawing dies in a previous occupation. I'm afraid that, after removing any useful screws and useable small lumps of cast iron, they went to the tip. I kept some rough diamonds to use in dressing tools.)
Cheers.
« Last Edit: July 13, 2017, 01:18:30 PM by philf »
« Reply #27 on: December 07, 2015, 01:06:46 AM »
Bloomin marvelous  :clap:  as usual David. It just goes to prove that you actually drill the holes in just the right place rather than sometimes.
« Reply #28 on: December 07, 2015, 03:14:58 PM »
Cheers.
You're a gem. PM, on it's way.......
« Reply #29 on: December 07, 2015, 03:52:02 PM »
John.
 With all the practice I've had, over so many years. I'm bound to get it right, occasionally......  :thumbup:
« Reply #30 on: December 08, 2015, 03:14:19 PM »
Here, is the finished gas conversion.  :thumbup:
Tank, held by single, knurled retaining nut......
The assembly, is held between the wooden rails. Enabling it to slide, as necessary........
Just noticed, in the last pic. I've forgotten to pickle n polish the burner!  :Doh:
Don't suppose, anyone will notice........
« Reply #31 on: December 08, 2015, 05:50:12 PM »
Your right I didn't!
« Reply #32 on: December 08, 2015, 05:57:23 PM »
You'll do for me, Tom!  :thumbup:
« Reply #33 on: December 09, 2015, 05:51:31 AM »
Just made a batch of shutters.
They don't like, (relatively), high revs. The operating arm, tears the 5thou brass. But, only on the down stroke.......  :scratch:
Background, templates. Centre, new stock. Foreground, oval holes........
I've ordered some 4mm brass washers. Going to solder one, surrounding the hole.  :thumbup:
« Reply #34 on: December 09, 2015, 10:54:47 AM »
Time for titanium shutters  :lol:
« Reply #35 on: December 09, 2015, 11:08:32 AM »
Do you have any in stock, Andrew?
(The noggin end of the graphite. Is earmarked for another, flame likker piston!).  :thumbup:
« Reply #36 on: December 09, 2015, 11:52:23 AM »
Got some titanium sheet but it's 2 mm thick and destined for nickel plating cages  :ddb:
« Reply #37 on: January 15, 2016, 03:34:44 PM »
When I drill the 4mm. shutter hole, on a piece of hardwood, a rollover is formed. Just the right size for a 4mm washer.
Flatted to clear underside of the cyl. head........
Had some soldering problems, with the protective varnish. Got there, in the end........
A quick video, of a fast proving run........
Shutters. Two on left, after a few seconds at speed. Third one after 6 hrs gentle running. Fourth one after several minutes at speed.....
I reckon, that's a success!  :thumbup:
« Reply #38 on: January 16, 2016, 06:39:09 AM »
 :clap:  :clap:  :clap:  :clap:  :clap:
Offline bertie_bassett
« Reply #39 on: January 16, 2016, 08:05:50 AM »
looks like your onto a winner there  :thumbup:
