Gallery, Projects and General > How do I??
48V lamp
Swarfing:
I would have to agree with you totally on that Bill
sparky961:
I have to add my support for the voltage doubler circuit. Its so elegantly simple. I wish I had a need to use that solution somewhere just so I could.
RussellT:
Thanks for all the suggestions - I'm thinking about it - and I'll need to talk to the machines owner. I think he might favour buying some 50V lamps - although if it were mine I think I'd go for Bill's voltage doubler.
srp:
I'm a bit late to this party, but I recently converted my LoVo light to an MR16 12v led, replacing the 440v transformer with an led driver. Because the 3 phase motor is run off a vfd, I decided the easiest way was to run a seperate 240v supply to the lamp and the coolant pump, and this supplies the driver which sits in the transformer box in place of the old 440v transformer.
I wish I'd known that adaptors from BC to MR16 were available though - I spent far too long faffing about making up a plate to hold the new lampholder! It works a treat though, with a daylight led lamp in (6000k I think) and if it gets damaged or splashed with coolant there is only 12 v to worry about.
hermetic:
If itm is a lovolite unit, some have different voltage tappings on the transformer unit.
Navigation
[0] Message Index
[*] Previous page
Go to full version
