The Shop > Metal Stuff
Where to get a large block of steel?
<< < (3/3)
John Rudd:
--- Quote from: Jasonb on November 14, 2015, 03:23:07 PM ---M-Machine do 2" x 5" flat bar cut to whatever length you need, I've had large stuff off them in the past, page 25
http://www.m-machine-metals.co.uk/mm_cat_2011.pdf
--- End quote ---
Oh bugger, I forgot about them....good spot Jason :bow:
krv3000:
hi im in Durham is 150 by 150 by 150 to big
dawesy:
It is a bit although it would just need a bit more machining down. I bear it in mind, thank you
Lew_Merrick_PE:
Merchant Stock (low carbon HRS) bar sells here in the U.S. for $1.60/lb ($3.53/kg) at this instant.  1 inch bar (which I usually dress to .950 inch (24.13 mm)) or 1.25 inch bar is available in 1/2 increments of width from 1 inch to 12 inches at almost any steel yard.  If you can find a "drop" from another cut (i.e. drawing to an inside straight), you can pick them up for $0.95/lb at my local steel yards.  2 inch and 2.25 inch bar is generally available though you may have to hit a couple of "yards" to find it.  ???
GRIFFIN:
Hi Dawsey,
Have you tried the metal supermarket? Check out their website, they have branches up and down the country.
I get most of my stuff from them.
Cheers, Griff.
Navigation
Message Index
Previous page
Go to full version
