Author Topic: tyre valve  (Read 4780 times)
tyre valve
« on: July 08, 2015, 07:40:38 PM »
hi all a bit off the wall tyre valve any one no watt thread they are not the out side where the cap goes on but the inside where the valve gets scruwd in
Re: tyre valve
« Reply #1 on: July 08, 2015, 08:29:07 PM »
Hi,
it' a Schraeder valve, here's a link, thread types a little bit down the page in dimensions.
https://en.wikipedia.org/wiki/Schrader_valve
Regards, Matthew.
Re: tyre valve
« Reply #2 on: July 09, 2015, 03:30:08 AM »
At one time Tracy Tools had the taps 'cos I've got some somewhere, and the little tool to get the valves out ...
Looking a bit doubtful now though ...  :scratch:
http://www.tracytools.com/taps-and-dies/schrader-valve-taps
Re: tyre valve
« Reply #3 on: July 09, 2015, 11:21:37 AM »
Making regulators?
Had a hss tap 17 yr ago though the cleanup ones are available from some car places along with higher pressure valves.
Re: tyre valve
« Reply #4 on: July 09, 2015, 06:00:22 PM »
thanks all its for work we use gas springs witch we refill but sum of the adapters that fit the regulator need now ones making so was wonting the thread type and size as we will need both tap and dye
Offline Steamer5
  • Country: nz
Re: tyre valve
« Reply #5 on: July 10, 2015, 01:30:32 AM »
Hi krv,
Just been thru the same exercise! I have one of the little tools to install / remove the valve it also cleans & cuts thread. I tried & couldn't get a seal. More googling & I found that you also need a taper or the seal to work!! So I cleaned the rubber off a tire valve stem, drilled out my home made fitting & loctited the stem in, works just great!
After doing this I found out that you can buy a fitting with the valve in it! :doh: check out your local hydraulic or phenumatic supply shop.
Cheers Kerrin
Kerrin
