Gallery, Projects and General > How do I??
Metric threds
vintageandclassicrepairs:
Hi Chipenter,
It may be worthwhile fabricating a new slotted "banjo to accomodate the different gears needed?
On a couple of lathes I worked on the wheels were 127 and 125 teeth to provide the metric threads
the pitches would then be "near" the imperial settings (ie. 20 tpi = 1.25mm so to speak)
This seemed easier to convert in my scrambled brain :smart: rather than your 127/100 combination (5:4 ish)
I always checked the pitch with a dial gauge against the carriage before cutting metal
HTH
chipenter:
--- Quote from: vintageandclassicrepairs on June 24, 2015, 06:02:18 PM ---Hi Chipenter,
HTH
--- End quote ---
That was my first thought to , I alredy have 100 and 40 gears and the 32 127 should be delivered tomorow , all I have to do is bore them to fit and bolt the 100/127 together , and should be a simple change over involving two bolts .
Pete.:
HTH
--- End quote ---
127 teeth provides perfect transposition. If you only wanted 'near enough' there are more conveniently-sized combinations that produce good enough threads to make fasteners etc.
chipenter:
Gears arived today got them bored out and bolted together , the fixed shaft is 3/4" x 2 1/4" and I will make spacers one 1 1/2 x 3/4 bore and one 3/8 x 11/16 bore for the lead screw end .
chipenter:
Got it finished the gears are nice and quiet and cut a 2mm pitch thread , using the instructions from Matt Tinkers Eggwick thread on screw cutting up to a shoulder , I have learnt something today thanks to Madmodder .
Navigation
[0] Message Index
[*] Previous page
Go to full version
