Author Topic: a £1 coune holder  (Read 10050 times)
a £1 coune holder
« on: February 16, 2015, 02:23:48 PM »
hi all well just a simpel project i have had lodes of £1 coun holders they hold a total of £10 but they all keep braking so i desided to mack my own in esence i just coped the plastic one for the sises i got sum bronse from work it all redy had a 13 mm hole runing thruw it so i just bord it out to the sise of the plastick one and to the same depth then turnd dawn the outer od just a bit biger than the origenel one then cut it off drest the top off then ran the lathe tool acros the top to mack the center of the tube then cut and filde one hafe dawn so the coune wood fit in i used the plunger top of the plastick one then mad a bung to go in to the bottom this was a press fit and ther you have it a £1 coune holder beter than the ones you can by pics
Offline porker
Re: a £1 coune holder
« Reply #1 on: February 16, 2015, 02:49:10 PM »
Neat, I really like that. Trying to work out how you did the end that retains the coin. Did you bore the £1 size hole to have a flat bottom and mill half off?
Sorry looked at the pictures and didn't read the bit how you made it.
I guess there is a spring to push the coins up too?
« Reply #2 on: February 16, 2015, 03:13:29 PM »
yep ther is a spring i set the boring bare to 65mm so once bord out to that depth i just whent to say 73mm in lenth then cut it off then tnurnd the top dawn to leve a 3mm lip then bord the 13mm hole out to leev a 5mm sholder this is wat the coune rest on when the spring pushes the coune up
« Reply #3 on: February 16, 2015, 03:49:20 PM »
How long to empty a clip on rapid fire ?
« Reply #4 on: February 16, 2015, 03:56:54 PM »
lol
« Reply #5 on: February 16, 2015, 03:57:57 PM »
Not very long these days the way prices have gone  :lol:
« Reply #6 on: February 16, 2015, 04:03:18 PM »
Better make another and duct tape it to the first, wouldn't want to get caught short in a fire sale fight.
Offline millwright
  • Leeds West Yorshire
« Reply #7 on: February 16, 2015, 04:13:20 PM »
I always save the £2 coins in the old 35mm film  plastic conainers, £30 in each one they soon add up. hope you have a good belt on yer keks bob with that lump of brass full of brass in yer pocket :lol:
« Reply #8 on: February 16, 2015, 04:59:12 PM »
 :thumbup: nice one Bob  :clap: :clap: :clap:
« Reply #9 on: February 16, 2015, 06:37:48 PM »
Nice bling Bob  :thumbup: How does the bottom bit attach that holds the coins in ? ......You will have to make another matching one to keep your coffee sweetners in lad  :dremel:
  Cheers Mick
« Reply #10 on: February 16, 2015, 08:58:06 PM »
I like that Bob! :clap:
Too bad we don't have any coins here worth that much. We'd have to make a whole walking stick! :beer:
« Reply #11 on: February 16, 2015, 09:32:12 PM »
10 of them in there, eh?  Isn't 10 pounds a bit heavy to keep in your pocket?  Sorry, couldn't resist.
« Reply #12 on: February 17, 2015, 01:31:48 PM »
thanks for the coments mick on the origenel one the bottom is just a plastck cap stuck on the bit that shuves the counes  to the top is a plunger with a spring just amagine a botel top of a botel of beer with a spring under it and the bottom on the one i made is just a press fit
