Author Topic: T slot cutter  (Read 4335 times)
Offline kayzed1
T slot cutter
« on: December 29, 2014, 02:06:46 PM »
Hi all i hope every one had a good Christmas. I have a Pm Crank Shaper Kit i thought it about time i started to put together, i have had a good look at the plans and have started to square it all up BUT! How do i cut t-slots to fit an 1/8th t-nut please? I can not find a cutter of that size in the shops do i have to try and make one, if so HOW!!! many thanks.
 Lyn.
Online mklotz
  • LA, CA, USA
Re: T slot cutter
« Reply #1 on: December 29, 2014, 02:45:24 PM »
I simply took a 1/8" endmill and ground away a portion behind the tip with a Dremel mounted in a toolpost holder I made.  Worked very well.
If you make one, save it.  The other PM machine tools use the same size T-slot.
Regards, Marv
Home Shop Freeware
Offline kayzed1
Re: T slot cutter
« Reply #2 on: December 29, 2014, 04:42:22 PM »
Thanks for the info, i had not thought of that, i was thinking " how am i going to hold some thing that small "   :doh:
now to order a 1/8th end mill.
Lyn.
