The Shop > Tools
OSAKI Mini Mill
Will_D:
After much deliberation I think its going to be this one:
SIEG Super X2P HiTorque Mill:
http://www.arceurotrade.co.uk/Catalogue/Machines-Accessories/Milling-Machines/Model-Super-X2-Plus-Mill/SIEG-Super-X2P-HiTorque-Mill
I really liked the OffTheShelf Amadeal AMA25DRO fitted but its just too big for me!
Reasons for the SX2P:
Bigger/Heavier, non swivelling column, Belt drive, Hi-Torque motor (well so they say)
Also Arc have a great reputation for after sales service, spares and imaginative upgrades.
Now only two questions left:
1. This mill does not have a moving quill as far as I can see! All drilling/milling involves the whole head moving up and down the column via the rack and pinion. There 'appears to be' a spring counter balance fitted, Does this work? Whats it like as a (expensive) pillar drill?
2. I intend to fit a set of decent glass or magnetic DROs and display. Any one done this already?
I know Arc have a OTS set for the X3 so as most of the little bits and bobs will probably fit I will ask them in the morning about a set of suitable scales!
velocette:
Hi Will
A good choice for a home workshop and a massive improvement on the earlier X2 which sadly was not available when I fitted out my home shop.
Had to spend a lot of time and extra cash to get it to perform reasonably well to be even near the SX2 specs.
""There 'appears to be' a spring counter balance fitted, Does this work? Whats it like as a (expensive) pillar drill?""
Reading this it appears that they still fit the spring assist on the mill head.
Sorry to rain on the parade but personally I found it to be very frustrating to use.
So it got removed and an "Air Spring" fitted inside the column to a frame attached to the mill head.
A longer rack fitted to give more head travel.
The "Air Spring" is ex automotive supply store for Station wagon counter balance Rated for 24 kgs and 220 mm travel.
All round performance both as a Mill and Drill is more than capable of all that is required in a home shop.
Enjoy and keep posting
SwarfnStuff:
I too have the older X2 and got fed up with the spring assist (actually, it was mostly a hindrance I reckon). It was a squeeze but I fitted an air spring OR gas strut inside the column at the same time I converted to belt drive after a head drop (I blame the spring, rather than the goose who forgot to adjust the column gib. :hammer:) smashed the internal gears. Well worth the effort but no reason why you cannot use as is until you feel the need to convert.
Will_D:
Thanks for the replies. Time to find the auld credit card.
Santa's late this year but he will need a bigger sack!
greenie:
I too have the old X2 and that later version - SX2 - is definitely a good buy, you should have it around for many years in your workshop.
The X2 I fitted onto the back of an Emco Maximat V10P lathe, then threw away that spring set-up altogether, used some weight lifting weights hanging from a pushbike brake cable, up over the top of the mast to counterbalance the head.
Works like a charm now, it's totally balanced and requires light finger pressure to raise or lower the head, the head does not fall when you don't want it too either.
Navigation
[0] Message Index
[*] Previous page
Go to full version
